WHat cams for me - Forums at Modded Mustangs
 1Likes
post #1 of 29 Old May 15th, 2015, 12:23 AM Thread Starter
WHat cams for me
Looking for some mild cams for my 06
DOnt want limiters or lockouts
want to use stock phasers obviously
want to use stock springs to want the 4500-6500 rpm range to pick up power mostly dont mind if i lose a little down low.
What options do i have?
4vGts is offline
post #2 of 29 Old May 15th, 2015, 01:17 AM
Insomniac
BIGCHRISS197's Avatar
I hear good stuff about cms. You get the good lope with more performance.
BIGCHRISS197 is offline
post #3 of 29 Old May 15th, 2015, 06:38 AM
Resident Headbanger
Bullitt95's Avatar
If you also want a near stock idle quality without much lope and, at the same time, more power at higher rpm, the CompCams 127200 NSR cams will be tailor made for you.
With those cams plus a CAI, CMDPs, UDP, LT headers, offroad midpipe, and a tune, you could have 350+rwhp or 400hp at the crank.
2006 GT Deluxe - 5MT - 12.52 @ 109.33
311rwhp 328rwtq with stage 1 bolt-ons
Bullitt95 is offline
post #4 of 29 Old May 15th, 2015, 09:40 AM
UNnaturally Aspirated
KawiBrian's Avatar
Can't go wrong with hot rods, I love mine
2007 Shelby GT500 - 3.4L Whipple, Kooks Longtubes, Kooks Catted X, Magnaflow Magnapacks, MGW Shifter
2007 GT/CS 5 Speed - Procharged, Cammed, Slammed - SOLD
2007 V6 5 Speed - SOLD
KawiBrian is offline
post #5 of 29 Old May 15th, 2015, 11:26 AM Thread Starter
The bbr stage 1 cams any good?
Do the comp 127200s require phaser mods?
4vGts is offline
post #6 of 29 Old May 15th, 2015, 12:51 PM
Resident Headbanger
Bullitt95's Avatar
No, and you don't need to change the stock valve springs either.
However the VSR 127300 cams do require a spring upgrade but not phaser limiters, while the Mutha Thumpr cams require phaser limiters but not a spring upgrade.
Hot rod cams and Detroit Rocker cams, like the 127200s, don't require a spring upgrade nor phaser limiters but they have a rougher idle and don't deliver the same HP gain.
post #7 of 29 Old May 15th, 2015, 01:41 PM Thread Starter
Cool. Are they ok for boost applications
4vGts is offline
post #8 of 29 Old May 15th, 2015, 02:28 PM
KawiBrian's Avatar
My tuner (Bill Miller of Pro Edge Tuning) said that he loves the hot rods and that they actually are pretty good for boosted applications, my car made great power with the hod rods and 9psi of boost and meth. Made 526rwhp
post #9 of 29 Old May 15th, 2015, 04:59 PM
I love to skydive
Durr4456's Avatar
There not ideal but they can work.
MM is awful. Don't ever come here if you haven't been sucked in already!
Durr4456 is offline
post #10 of 29 Old May 15th, 2015, 09:13 PM Thread Starter
Ok im having trouble finding some for a decent price 719 is the lowest ive seen.
4vGts is offline
post #11 of 29 Old May 16th, 2015, 04:41 AM
Resident Headbanger
Bullitt95's Avatar
Most of the popular 3v performance cams fall somewhere in the $700-800 range and depending on the mileage of your engine, it might be wise to replace the phasers plus the timing chains/tensioners at the same time. Some might even recommend replacing the roller finger followers but I'd check their condition first.
As for boosted applications, all the cams mentioned would do fine but ideally you'd want cams that have a wider lobe separation angle (less valve overlap) and a longer exhaust valve opening duration, so the 127200s come closest. The stock cams are also very good for boosted applications.
post #12 of 29 Old May 16th, 2015, 11:19 AM Thread Starter
Ok i was just asking because i still want room to grow. My car only has 95k miles and its pretty well taken care of imo
4vGts is offline
post #13 of 29 Old May 16th, 2015, 02:45 PM
Resident Headbanger
Bullitt95's Avatar
Yeah, as long as the engine's had oil changes at the proper intervals and hasn't been driven hard, you shouldn't need to change anything else but the cams.
post #14 of 29 Old May 16th, 2015, 04:41 PM Thread Starter
Yea when i get it apart ill inspect everything and go from there
---------- Post added at 01:41 PM ---------- Previous post was at 12:20 PM ----------
has someone written down the specs for detroit rockers?
4vGts is offline
post #15 of 29 Old May 16th, 2015, 05:17 PM
I've posted up plenty of info on the other cam thread on the front page, you could have just read that. Anyways, if your planning on doing boost sometime, don't get any of the idle sound cams. To maximize the gains from such a mild cam (NSR) you need to find one with the largest LSA with the longest duration as possible. Also you should get a blower specific grind, it will tend to have a little more exhaust duration relative to intake duration.
Cams should be one of the last mods you do as they can be pretty specific as far as where you want the power band and also what would be best for your set up. Cam choice should be specific to each build. Your not going to get the optimum response from folks on here.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #16 of 29 Old May 16th, 2015, 05:33 PM Thread Starter
Oh im with you all the way on the last choice but the install is to easy so if need be ill change down the road. How are the 127050s?
4vGts is offline
post #17 of 29 Old May 16th, 2015, 08:09 PM
CMS cams.....BOOM!
07 gt, CMS cams, hurst, CAI/tuned, LT's, o/r h, m80's, FRPP mani, UDP, lowered with steeda 1.25/1.5, exedy mach 400/race flywheel, 1-pc DS, BMR upper/lowers, 4.10's, CHE brace with TL's, and a few other things that dont add up to much.
fzr confused is offline
post #18 of 29 Old May 17th, 2015, 03:14 AM Thread Starter
Anyone know anyone selling the 127200s. I have cash to buy but not brand new, looking for first cousin price!
4vGts is offline
post #19 of 29 Old May 17th, 2015, 06:01 AM
Resident Headbanger
Bullitt95's Avatar
Maybe you're a first cousin of Brent at Brenspeed and you just don't know it.
post #20 of 29 Old May 17th, 2015, 11:30 AM Thread Starter
They want 719 plus s&h. Or is there a discount i am missing?
4vGts is offline
