97 GT P0232 help - Forums at Modded Mustangs
post #1 of 9 Old May 15th, 2015, 10:58 AM Thread Starter
Moe4860's Avatar
97 GT P0232 help
Hi to everyone out there...
So here's my issue....this morning tried to wake the beast up and i noticed the fuel pump did not turn on...car would not start because of that. P0232 is the code i got when i scanned the pc.
I recently replaced the relay module in the fender and that made it work for about 1-2 weeks. Before i replaced that i ran a pressure test to check that the fuel pump was still working and it met the minimum requirement.
Not sure what else to do here? Can it be a bad pcm? How do you check the inertia switch? The car does have an sct tune. I've already restored stock tune and upload new tune and still no pump turning on...
Moe4860 is offline
post #2 of 9 Old May 15th, 2015, 03:03 PM
97Roush's Avatar
Not sure if it would help, but theres that button behind the driver side tail light? I had that same issue once and when I pressed that I was all set to go. Just a quick check
"Ford came under fire when a memo revealed that the automaker had decided it would be cheaper to pay off lawsuits for any Pinto deaths than to pay for a redesign of the vehicle."
97Roush is offline
post #3 of 9 Old May 15th, 2015, 03:12 PM Thread Starter
Moe4860's Avatar
Yeah the inertia switch wasn't tripped so i couldn't push on it. Any other thoughts?
Moe4860 is offline
post #4 of 9 Old May 15th, 2015, 04:26 PM
96gtstang&V6's Avatar
Would there be a fuse that may have popped that might have something to do with it?
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd
1996 mustang gt- 5spd, black, cobra hood, stock
November Birthday Club Founder
Old username: 97gt
www.discounttiredirect.com
96gtstang&V6 is offline
post #5 of 9 Old May 15th, 2015, 05:14 PM Thread Starter
Moe4860's Avatar
All. Fuses are good.
Moe4860 is offline
post #6 of 9 Old May 15th, 2015, 06:43 PM
have you tried cleaning the ccrm? it could be bad pcm or a short in the wiring.
have you checked fuel pressure?
Old username: 97gt
post #7 of 9 Old May 16th, 2015, 12:21 AM
07gtS197's Avatar
iTrader: 5 reviews
Swap out the relay with another one to verify the new one isnt your culprit
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is online now
post #8 of 9 Old May 16th, 2015, 11:59 PM
Go to your CCRM connector. Install a jumper from pin 11 (Yellow - 12v source), to pin 5 (Dk Grn/Yel - to fuel pump). If your pump doesnt come on verify you have 12v on pin 11. If so, either the relay is done or your pump is done. Could be a few more things, but that requires more in depth troubleshooting. Let me know if you want some detailed schematics and I can email them to you.
soupnutz is offline
post #9 of 9 Old May 17th, 2015, 01:44 AM Thread Starter
Moe4860's Avatar
Soupnutz you are the man!..jumped the wire and it turned out as a bad pump since the ccrm was just replaced a month ago...put in a new pump and im growling at 4 bangars al l over again.! Thanks to everyone who contributed.
Moe4860 is offline
