Intermitten miss - Forums at Modded Mustangs
post #1 of 66 Old June 1st, 2015, 09:43 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
Intermitten miss
The other day I did my spark plugs and all was well until I drove it saturday. It drove fine but I noticed it was running a little rough. After about 40 miles of driving, I noticed it was noticably rougher, there was a tick coming from near the tailpipes and theres a raw gas smell coming out of the exhaust. Ive already tried pulling each cop one by one to see if one would make no difference but they all made the motor run worse. Im guessing one of my injectors is sticking but I dont know how to check them.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is online now
post #2 of 66 Old June 1st, 2015, 09:48 PM
Pull any codes?
07 gt, CMS cams, hurst, CAI/tuned, LT's, o/r h, m80's, FRPP mani, UDP, lowered with steeda 1.25/1.5, exedy mach 400/race flywheel, 1-pc DS, BMR upper/lowers, 4.10's, CHE brace with TL's, and a few other things that dont add up to much.
fzr confused is offline
post #3 of 66 Old June 1st, 2015, 09:55 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
No codes
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #4 of 66 Old June 1st, 2015, 10:00 PM
Insomniac
BIGCHRISS197's Avatar
Make sure your spark plugs didnt back out and all your cops ares seated.
BIGCHRISS197 is offline
post #5 of 66 Old June 1st, 2015, 10:11 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
I can mess with them tomorrow just to be sure and I think Ill pull one just to see what it looks like.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #6 of 66 Old June 2nd, 2015, 12:09 PM
Pull your plugs and check them. Doubt an injector went bad at the same time you did your plugs. One time at band camp, I had a plug with a cracked insulator around the electrode. When you held the plug up to examine it, everything looked fine. But when you turned it and put it in the head, the insulator slide down and covered the electrode. I pulled that plug 3 times before I caught it. And if plugs was all you did, 99% of the time it is the work you just performed that causes the problem. I would clean your MAF too for shits and giggles.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #7 of 66 Old June 2nd, 2015, 01:43 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
Thanks boss, I really didnt want to pull them but I have tomorrow off so Ill do it then. I even checked my injectors with my multimeter and they all checked out.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #8 of 66 Old June 2nd, 2015, 03:13 PM
It should only take you a few minutes to pull them. It's not like they're gonna break now.
07 Boss is offline
post #9 of 66 Old June 2nd, 2015, 04:57 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
Im gonna pull them and check my cam sensors while Im out there. Now that I had time to think, Ive noticed the past couple of months when Id accelerate, the throttle would like "step" up instead of smoothly accelerate and I read that could be caused by cam sensors failing. Ill still pull my plugs to verify that theyre fine though but Im leaning towards cam sensors. I pulled each cop one by one and all of them would make it idle worse so I know that none of the plugs are missing.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #10 of 66 Old June 2nd, 2015, 05:15 PM
What gets me as sketchy is that all of the stuff you are looking at would normally throw a code or two. That is why I'm kinda trying to think a little outside the box. Bad sensors or solenoids would typically throw a code.
Check/clean your MAF and all of your intake couplings/connections. Those items won't throw a code.
07 Boss is offline
post #11 of 66 Old June 2nd, 2015, 06:06 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
And even though its running rough and might have a miss its still not throwing a code. I checked last night and it now has codes for when I unplugged the cop's but thats it. Ive seen where it wont throw a code for a bad cam sensor so its in the realm of possibility that theyve failed. Im definately also gonna clean the maf and pull my plugs tomorrow but Id also like to check these other parts before I go that extra step and pull the plugs. This car is my dd so I cant mess with it as much as Id like.
I appreciate you thinking outside the box for me, its giving me food for thought on what to check
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #12 of 66 Old June 2nd, 2015, 06:43 PM
Pull the plugs, won't take more than 5-10 minutes to pull all of them. Start there. Leave the battery unplugged for 20-30 minutes and go for a drive.
post #13 of 66 Old June 2nd, 2015, 07:28 PM
How you gonna go for a drive with the battery and plugs pulled?
07 Boss is offline
post #14 of 66 Old June 2nd, 2015, 07:42 PM
Hello? Mcfly! :p
post #15 of 66 Old June 2nd, 2015, 08:18 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
Lol yea Ill do that. I see on my tuner now you can clear kam on it instead of having to unplug the battery for a while. I think Ill give that a shot
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #16 of 66 Old June 3rd, 2015, 01:36 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
Ok I pulled the plugs and this is what I found
In case you cant see it well, the porcelain part of the plug is free to move and is covering the electrode. My guess is that all the plugs are defective so I called am and theyre gonna refund my money. I wish I wouldve just went with the brisks in the first place...
Anyway, Im gonna put the refund money towards brisk one piece plugs and not deal with the stock crap plugs.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #17 of 66 Old June 3rd, 2015, 02:02 PM
Attachment 152217
Attachment 152225
Lol, I think somebody told that story earlier, post #6 . I think it happened at band camp or something like that.
07 Boss is offline
post #18 of 66 Old June 3rd, 2015, 02:02 PM
Insomniac
Guess you found your miss lol
post #19 of 66 Old June 3rd, 2015, 02:13 PM Thread Starter
07gtS197's Avatar
iTrader: 5 reviews
Lol mcfly over here. Ive heard of this happening before too but I thought I wouldnt get a bum set like that. How aweful is that, we cant even get a decent set of oem plugs for our cars.
---------- Post added at 02:13 PM ---------- Previous post was at 02:12 PM ----------
I cant believe it, well I can but really all of them were defective really. Thats terrible, Ill never buy a set of stock plugs again
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #20 of 66 Old June 3rd, 2015, 02:34 PM
Having 1 break can happen, having 8 break takes practice.
