Intake manifold - Forums at Modded Mustangs
post #1 of 26 Old June 22nd, 2015, 08:07 PM Thread Starter
Tig3rb8
KonaGt's Avatar
Intake manifold
Is a Frpp Intake Manifold worth the money with my current mods ....JLT Series 3 110mm Cai, 62 mm TB, O/R H ? Headers to follow months away .
2010 Gt Premium - sold
2016 Gt 5spd Magnetic Metallic
KonaGt is offline
post #2 of 26 Old June 22nd, 2015, 08:51 PM
No, spend the money elsewhere.
07 gt, CMS cams, hurst, CAI/tuned, LT's, o/r h, m80's, FRPP mani, UDP, lowered with steeda 1.25/1.5, exedy mach 400/race flywheel, 1-pc DS, BMR upper/lowers, 4.10's, CHE brace with TL's, and a few other things that dont add up to much.
fzr confused is offline
post #3 of 26 Old June 22nd, 2015, 09:40 PM Thread Starter
Tig3rb8
KonaGt's Avatar
OK thx......headers it is !
KonaGt is offline
post #4 of 26 Old June 22nd, 2015, 09:44 PM
The only real gain without cams is from the delete plates/plugs, which you already have. Even with my cams and everything else, I felt zero gain from it
post #5 of 26 Old June 22nd, 2015, 09:52 PM Thread Starter
Tig3rb8
KonaGt's Avatar
Yeah that's why I asked.....so I'll prolly put that money towards my Lt's and mid pipe ......thx friend
KonaGt is offline
post #6 of 26 Old June 23rd, 2015, 04:56 AM
Resident Headbanger
Bullitt95's Avatar
Nope. The FRPP manifold will actually cost you torque in the 3300-5200rpm band where the stock manifold performs at its best, and only produce torque gains at the very top end from 5200rpm to the rev limiter.
Even LT headers would be a questionable upgrade since you've already gained 1/2 of the HP/TQ that they'd yield by installing an offroad midpipe. I suggest you swap in a set of Steeda UDPs instead.
I have exactly the same phase 1 mods as the Brenspeed high mile Mustang project vehicle (JLT 3 CAI, Steeda UDPs, CMDPs, FRPP X-pipe with stock cats, Brenspeed 91 octane tune).
2006 GT Deluxe - 5MT - 12.50 @ 109.61
314rwhp 330rwtq with basic bolt-ons
Bullitt95 is offline
post #7 of 26 Old June 23rd, 2015, 11:10 AM
Like A Boss
crackpotfox's Avatar
If you end up getting the manifold, get it from brenspeed. It's $500 something from them, 600+ from other places iirc.
Carolina Crew #54
Always Clean Crew
Originally Posted by narleycarley View Post
I coached his boy in basketball last season. Giggity giggity
crackpotfox is offline
post #8 of 26 Old June 24th, 2015, 08:52 PM Thread Starter
Tig3rb8
KonaGt's Avatar
Do UDP's require turning ?.......if they are so bad off then why isn't there any used ones for sale ? I figured it would be a good buy since I plan on going F/I next summer ...
---------- Post added at 06:52 PM ---------- Previous post was at 06:52 PM ----------
OK thx for the heads up ...
KonaGt is offline
post #9 of 26 Old June 25th, 2015, 04:16 AM
Resident Headbanger
Bullitt95's Avatar
Underdrive pulleys (UDPs) don't require a tune simply because their function is to reduce the parasitic HP losses from the belt-driven ancillaries. You won't find used ones for sale 'cause most people don't remove them once they're on the car unless they add a supercharger later on. If you're planning to add turbos, you can keep the UDPs.
post #10 of 26 Old June 25th, 2015, 09:14 PM Thread Starter
Tig3rb8
KonaGt's Avatar
I was referring to used intake manifolds when I said I don't see any for sale if theres a torque lost ? Yeah UDP's will be next .
KonaGt is offline
post #11 of 26 Old June 25th, 2015, 10:08 PM
Turbo Maniac
Weather Man's Avatar
There is one for sale over on S197. It does help breathing up top. For regular city driving it would definitely soften up the bottom.
Coast 302 Stroker & Stuff
707 HP 651 TQ 13 PSI
Weather Man is offline
post #12 of 26 Old June 25th, 2015, 10:39 PM Thread Starter
Tig3rb8
KonaGt's Avatar
OK thx for the info...
KonaGt is offline
post #13 of 26 Old June 25th, 2015, 11:45 PM
fairlane_68's Avatar
Next question...I've read from one source and seen firsthand on a local Mustang what the FRPP intake and Hot Rod cams can do. I've installed several Hot Rod cams in customer's cars, but never with the intake. Do they make a good combo, or is the intake just a show piece?
You've never really built or restored a car until you've crossed at least one state line to chase down a part.
Rescuing a Roush: the story of Buttercup
fairlane_68 is offline
post #14 of 26 Old June 26th, 2015, 12:58 AM
Turbo Maniac
Hotrods, FRPP intake and throttle body and JLT 3 intake versus bone stock on same dyno.
post #15 of 26 Old June 26th, 2015, 02:41 AM
Weatherman what does mod mean
4vGts is offline
post #16 of 26 Old June 26th, 2015, 06:45 AM
Darwin's Avatar
Mod is with the hot rod cams, ffrp intake and the jlt cai and tune I do believe.
Originally Posted by LethalDosage View Post
Something about your avatar creeps me the fuck out.
2006 GT AUTO Mods:
Ford Racing Intake Manifold, 93 TUNE, UDPs, FRPP 4.10, LT's, catted X, LCA, Adj UCA, 3K Converter and P275/40R17 MT, HR cams and Paxton 1200sl
Darwin is offline
post #17 of 26 Old June 26th, 2015, 07:10 AM
Resident Headbanger
Bullitt95's Avatar
The FRPP intake manifold is usually installed in conjunction with a 62mm TB and performance cams so you'd find that the engine screams when you get past 5000rpm but feels softer lower down. Many people swap in higher ratio axle gears (3.73 or 4.10) to compensate for the loss of lower rpm torque and get the engine into its powerband quicker.
post #18 of 26 Old June 26th, 2015, 09:12 AM
Turbo Maniac
Correct. I did swap to 4.10 gears also. It was a lot of fun playing on the top of the tach, she really pulled hard.
post #19 of 26 Old June 27th, 2015, 11:33 PM Thread Starter
Tig3rb8
KonaGt's Avatar
So hp is lost from 2000-4000 rpm ? So with the taller runners, slightly bigger TB and bigger Cai allowing more air to come into the engine HP gets lost ? WTF
KonaGt is offline
post #20 of 26 Old June 28th, 2015, 12:09 AM
Turbo Maniac
One word...velocity.
