Sway Bars - Forums at Modded Mustangs
post #1 of 32 Old July 3rd, 2015, 12:11 PM Thread Starter
Tini Tini Bo Bini
Ace417's Avatar
Sway Bars
Hey guys, what sway bar is everyone running? I need to replace mine and I'm thinking about going with either a steeda or BMR kit. Im not sure if I should get an adjustable kit or not. Does anyone have suggestions?
2007 GT - Gone
2016 FoST
What am I, some kind of nipple whisperer?
Ace417 is offline
post #2 of 32 Old July 3rd, 2015, 12:57 PM
I have eibach but I got it like that so not sure how it would be without but it is very stabil front and rear around turns, have never taken a curve over 50mph but it has held dang well until then
LoveTheBlue is offline
post #3 of 32 Old July 3rd, 2015, 03:15 PM
afelliott's Avatar
Send a message via MSN to afelliott
im running the ford racing GT500 sway bars, they handle a little better then the ones for the GT's, imo.
FRPPManifold HotRod CAMS 4.10 GT500Mounts & SwayBar
HRSportSprings
SteedaSTB ReloBrkt, UDP
JMUCA LCA PHB
SLPLT XPIPE LM
UPRKMember
KONIStrut Shocks
JLTS3CAI
BULLITT18x9 18x10
SRRSTB BSK
BAMA93R
350RWHP
afelliott is offline
post #4 of 32 Old July 3rd, 2015, 04:47 PM
Turbo > blower
Towelie's Avatar
whats a sway bar
Turbo build thread
sig by xocolleenox
Convertible Crew #27
Towelie is offline
post #5 of 32 Old July 4th, 2015, 12:50 AM
What is this sway bar thingy we are talking about? I have one on the rear but it's coming off soon too.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #6 of 32 Old July 4th, 2015, 01:23 PM Thread Starter
Tini Tini Bo Bini
Ace417's Avatar
I cant tell if you guys are fucking with me or not.
2007 GT - Gone
2016 FoST
Ace417 is offline
post #7 of 32 Old July 4th, 2015, 01:30 PM
Turbo > blower
Towelie's Avatar
neither of us run front ones
---------- Post added at 12:30 PM ---------- Previous post was at 12:24 PM ----------
why are you getting rid of the rear one? wouldn't that hurt your launches?
Turbo build thread
sig by xocolleenox
Towelie is offline
post #8 of 32 Old July 4th, 2015, 01:45 PM
Cause I'm gonna get the BMR Extreme Anti-Roll Bar. The one where you weld in the tabs. Gonna make it real stiff.
07 Boss is offline
post #9 of 32 Old July 4th, 2015, 01:45 PM
The sway bar shouldn't effect launching the car
2000 GT
Mods: BBK CAI, Typhoon Intake Manifold, PP throttle body/Plenum, Underdrive pulleys, Weight reduction, 3.73, J&M UCA, MM LCA, MGW shifter, Pypes M80, UPR O/R X Pipe, BBK spring isloators, MM pinion snuubber,AC delete
ShiftinGT is offline
post #10 of 32 Old July 4th, 2015, 01:47 PM
Turbo > blower
Towelie's Avatar
ah i see
It does because without a rear sway bar, the axle tries to pivot and it unloads one wheel.
Turbo build thread
sig by xocolleenox
Towelie is offline
post #11 of 32 Old July 4th, 2015, 02:41 PM
Lol, WUT? Suspension set up is vital For making good launches. Please explain how sway bars don't make a difference.
07 Boss is offline
post #12 of 32 Old July 4th, 2015, 02:46 PM
Turbo > blower
Towelie's Avatar
I think he was talking about the front sway
Turbo build thread
sig by xocolleenox
Towelie is offline
post #13 of 32 Old July 4th, 2015, 03:05 PM
Front sway bar makes a difference in how you launch also. I just want to hear what urban myths there are about drag racing suspension set ups and why he thinks sway bars, front or rear, aren't going to make any difference.
07 Boss is offline
post #14 of 32 Old July 4th, 2015, 03:08 PM
Turbo > blower
Towelie's Avatar
didn't know that. I just figured it was dead weight in a car that isnt carving corners
Turbo build thread
sig by xocolleenox
Towelie is offline
post #15 of 32 Old July 4th, 2015, 03:42 PM
afelliott's Avatar
yes and no, at my power level, the sway bar (stiff or loose) does not make a difference on my launches.
i have played around with these specs this past month at my local test and tune.
but im sure if you are pushing more than 500 to the wheels i can see it affecting your launches. but if your NA, like me, yeah the sway bars settings and or removal do not make a difference. if any at all it would be a .005 % difference in gains (ET, launch, etc.)
i got to this conclusion by averaging my runs with 9 (3 each) passes at different settings , with a control of stock sway bars. and a final 3 runs of running no front sway bar, front and rear strut bars. ran in average 12.880-13.10's. variable of temperature and gas in the tank.
so for low power level people like me, sway bars dont make a whole lot of difference. but you guys running FI. yeah i can see it make a world of difference.
but it makes getting to work in the mornings sooooo much fun with stiff suspension.
forgot to mention, i put my stock springs in the rear. not sure if that made a difference,(softer springs=better launches?) but it gives a nice stance.
any ways op, i would go with adjustable, to answer your question. i found it easier to drive in wet and dry conditions by loosening and stiffening the suspension through out the year.
HRSportSprings
JMUCA LCA PHB
SLPLT XPIPE LM
UPRKMember
KONIStrut Shocks
JLTS3CAI
BULLITT18x9 18x10
SRRSTB BSK
BAMA93R
350RWHP
post #16 of 32 Old July 4th, 2015, 06:47 PM
I tend to disagree. Lower hp cars rely more on set up to make them quick as opposed to sheer hp. I have found it is more important to concentrate on dialing the car's supension in to give it every possible advantage.
And I've tried the stock springs on the rear and really like the stance. As far as launching I think they were too soft. You really don't want to squat the car in launch. In fact you really want the axle to push away from the car.
07 Boss is offline
post #17 of 32 Old July 7th, 2015, 12:54 PM Thread Starter
Tini Tini Bo Bini
Ace417's Avatar
Welp. I guess Ill get adjustable. I was all about spending less money though
2007 GT - Gone
2016 FoST
Ace417 is offline
post #18 of 32 Old July 9th, 2015, 04:32 AM
At the Apex pulling 1.28g
Whiskey11's Avatar
Send a message via Yahoo to Whiskey11
I ran the Strano Performance Parts bars which are Hellwigg bars. Adjustable front and rear. Front is 35mm, rear was 25mm. Had options for a 28mm rear bar as well but thought that was WAY too much bar... never really used the 25mm rear bar much and opted for a much higher rear roll center.
2015 Mustang GT/PP Autocross Build Thread:
https://www.moddedmustangs.com/forums...-pp-build.html
Whiskey11 is offline
post #19 of 32 Old July 17th, 2015, 10:34 AM Thread Starter
Tini Tini Bo Bini
Ace417's Avatar
Uhh...i dont know what any of those measurements are for
2007 GT - Gone
2016 FoST
Ace417 is offline
post #20 of 32 Old July 17th, 2015, 01:44 PM
Eat Springs, Shit Valves
AnotherS197GT's Avatar
iTrader: 11 reviews
I run the BMR SB041 on the front of my car and the SB023 for the rear. I'm really happy with the performance of both of the bars, and they're reasonably priced too. The SB041 is a big bar and is most definitely overkill, but I wanted to have that extra bar rate just in case I decided to start doing auto-x or something like that in the future. They do have a smaller bar SB022 that will work well for a street car. Adjustable is great too, because you can set it softer or stiffer and see which set up you like better. I'm actually getting ready to set my front bar stiffer, the rear isn't adjustable.
AnotherS197GT is offline
