Under the valve covers - Forums at Modded Mustangs
post #1 of 23 Old August 3rd, 2015, 02:02 PM Thread Starter
Jetdude's Avatar
Recently got my son an 06 GT that needs some work. It has 140k miles and was clearly neglected. The engine was missing under a load which new spark plugs cured(kudos to this forum form the plug change technique). Currently we are chasing the p0345, 349 cam potion sensor codes. I have replaced both sensors and the alternator but the codes still come up. I am going to pull the drivers side valve cover and and am looking for some input on what problems to look for.
It also has a failed(stripped gears) IMRC actuators which I have locked in the full open position until we can find a new actuator.
The car severely lacks power in the upper rpm range.
Any thoughts are greatly appreciated.
Jetdude is offline
post #2 of 23 Old August 3rd, 2015, 02:43 PM
Resident Headbanger
Bullitt95's Avatar
You could just delete the CMCVs altogether and gain a few HP in the bargain. The lack of upper rpm power and cam codes could be due to a faulty solenoid that's preventing the phasers from retarding the cam timing (hence no "VTEC" effect).
2006 GT Deluxe - 5MT - 12.52 @ 109.33
314rwhp 330rwtq with basic bolt-ons
Bullitt95 is offline
post #3 of 23 Old August 3rd, 2015, 02:51 PM
07gtS197's Avatar
iTrader: 5 reviews
While you have the valve cover off verify cam timing to rule out the cams jumping a tooth.
Also what alternator did you get? Our factory ones are crap and Ive heard to get ones from a crown vic because apparently theyre a lot better.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is online now
post #4 of 23 Old August 3rd, 2015, 03:43 PM Thread Starter
Jetdude's Avatar
Too late on the alternator, got the lifetime warrantied one from Advanced.
By looking at the cam phasers can you tell if there is a problem?
Can the solenoids be swapped from side to side?
Jetdude is offline
post #5 of 23 Old August 3rd, 2015, 05:46 PM
what year Crown Vic has the same alternator?
http://i489.photobucket.com/albums/rr254/svtwin73/image_zpsc7776416.jpg
5.0 stroker, Roush 2300 w/3.2", 10% overcrank, Bullet-RGR spec cams, Kooks LT w/cats, FM axle back, TruTrac 3.73
Svtwin73 is offline
post #6 of 23 Old August 3rd, 2015, 05:53 PM
Solenoids can be swapped side to side to rule them out, but usually you can see that it's broken. The screen will be torn up.
To check the timing you would have to pull the front cover as well. While the covers are off check out the cam phaser for visual defects. I had a phaser go out of me and caused an over retard CEL. I could spin the timing mark portion of it with my hand, entirely too soft.
07 gt, CMS cams, hurst, CAI/tuned, LT's, o/r h, m80's, FRPP mani, UDP, lowered with steeda 1.25/1.5, exedy mach 400/race flywheel, 1-pc DS, BMR upper/lowers, 4.10's, CHE brace with TL's, and a few other things that dont add up to much.
fzr confused is offline
post #7 of 23 Old August 3rd, 2015, 07:36 PM
07gtS197's Avatar
iTrader: 5 reviews
I took this screenshot a long time ago so I could swap mine out one day when mine went out. Now whether its correct Im not sure but nobody else in the thread fought him so hopefully hes right.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #8 of 23 Old August 3rd, 2015, 07:40 PM Thread Starter
Jetdude's Avatar
Both solenoid's screens looked good, swapped them side to side for good measure.
Everything else seems ok, chains are tight, nothing seems loose or broken.
Jetdude is offline
post #9 of 23 Old August 3rd, 2015, 08:02 PM
Have you checked the crank sensor? Cam sensors key of of this signal. It's a long shot. I'm betting it's in the wiring somewhere. Check all connector pins. Unwrap wire harness and follow the wires all the way. Double check your grounds too. Those codes refer to the signal and the circuit as opposed to the actual position of the cam. It's electrical. If all of that checks out I would have to suspect a malfunction within the PCM.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #10 of 23 Old August 3rd, 2015, 08:20 PM Thread Starter
Jetdude's Avatar
Thanks, I will take a look at the crank position sensor and the wiring.
Do you think this cam sensor issue would cause the lack of power at higher rpm?
Jetdude is offline
post #11 of 23 Old August 3rd, 2015, 11:16 PM
It might but I don't know no suppose if it can't determine where the cam is it will throw off the tune. Not real versed on variable cam timing. First car I've ever built with it.
07 Boss is offline
post #12 of 23 Old August 4th, 2015, 10:08 AM Thread Starter
Jetdude's Avatar
Has anyone actually seen a case where the timing chain jumped out of time on a stock untouched engine?
Jetdude is offline
post #13 of 23 Old August 4th, 2015, 11:40 AM
If the plungers were bad, yes.
post #14 of 23 Old August 11th, 2015, 08:26 PM Thread Starter
Jetdude's Avatar
Ok, it's official. I have seen a motor first hand that has jumped out of time. The driver side cam is 1 tooth off. It was easy to see why with the timing chain cover off. The passenger side upper guide had broken loose from its upper mounting bolt and an 8" piece of the guide was just laying on top of the chain. The drivers side lower guide had some how stripped the lower mounting bolt, which also holds the oil pump on, out of the block. Needless to say there was a LOT of play in the chains!
So now I have to helicoil the bolt hole in the block and also account for some missing chain guide pieces.
I will head out tomorrow and get some parts on order, ie timing chain set, oil pump, water pump...
Can someone tell me if the oil pan can be taken off with the engine in the car? It looks like it can if I jack the motor slightly.
Jetdude is offline
post #15 of 23 Old August 11th, 2015, 09:10 PM
I hear the oil pan can be removed with lifting the motor a bit.
post #16 of 23 Old August 12th, 2015, 03:18 PM
Jack the engine up by unbolting eginge mounts and jacking up on crank pulley, it's strong enough to hold. It can be done this way, but still very difficult
2006 Lime Green Mustang GT
-Rebuilt at .020 over (stock compression)
-NSR Comp stage 2 cams
-BBK CAI
-BBK 62mm TB
-BBK shorties
-High flow catted X
-a/c delete
-Bama tuned
312rwhp/311rwtq
All mods are questionable- bought "built"
LoveTheBlue is offline
post #17 of 23 Old August 12th, 2015, 03:29 PM
FBGM
Ive seen it happen too. Just not on these cars but on a Subaru.
Saleen SuperCharged, C500 Side Exhaust, Cervinis Ram Air IV Hood, Hurst Short Throw Shifter, Chrome GT500 Replica wheels, GT500 Front Splitter ModBMR 1.25 Lowering Springs, ADJ Panhard Bar, CHE Torque Limiters and K Member Brace
kmac1622 is offline
post #18 of 23 Old August 14th, 2015, 11:30 AM Thread Starter
Jetdude's Avatar
Ok, timing chains, guides, tentioners and oil pump all changed. No more rattling on start up. Car runs great until 4k rpm and just stops pulling. Still has codes P0345 "Cam Position Sensor A Circuit Bank 2" and P0349 "Cam Position Sensor A Circuit Intermittent Bank 2". It's time to chase some wires. Does anyone have a wiring diagram that shows the cam position sensors to the computer? Do the Haynes manuals have descent schematics? My SCT tuner should be here any day. Will try to do some data logs then, hopefully something shows up..
Jetdude is offline
post #19 of 23 Old August 14th, 2015, 12:51 PM
I will take a look at the Haynes manual when I get home and post pics if they are there.
post #20 of 23 Old August 14th, 2015, 02:46 PM Thread Starter
Jetdude's Avatar
Also, how would I know if a phaser was bad? It isn't noisy.
Jetdude is offline
