Back up cameras - Forums at Modded Mustangs
post #1 of 25 Old October 1st, 2015, 05:46 PM Thread Starter
AR Stang's Avatar
Back up cameras
I have been reading around online and looked at the key hole setups people have and while it looks neat I don't want to hassle with all that. Has anyone used something like the links posted below? I figure the one in the light itself will look a lot cleaner than drilling a hole in the bumper.
Car Camera For Ford Mustang GT / CS 2005~2014 High Quality Rear View Back Up Camera For TOPGEAR Friends | CCD + RCA on Aliexpress.com | Alibaba Group
AR Stang is offline
post #2 of 25 Old October 1st, 2015, 05:58 PM
They make license plate frames with the cameras on them. I think those are the least obtrusive.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #3 of 25 Old October 1st, 2015, 06:05 PM Thread Starter
AR Stang's Avatar
My friend has that on his and while it works great the thing just looks out of place and like it wasn't meant to be there. I don't want it to look cheap.
AR Stang is offline
post #4 of 25 Old October 1st, 2015, 07:15 PM
I think they all look out of place and added on. The keyhole one is the least of the offenders, but you said you didn't want that one.
07 Boss is offline
post #5 of 25 Old October 1st, 2015, 09:25 PM Thread Starter
AR Stang's Avatar
I just know with my luck I would need in my trunk and the seats would get stuck and not come down and my fobs would stop working. I need a trunk release button already. I went ahead and ordered the Amazon one. Says it will be here end of October for some reason. I will add photos of it when I install it.
AR Stang is offline
post #6 of 25 Old October 1st, 2015, 10:13 PM
Trunk release button is easy. Just a momentary button and some wire. You can wire it right from the passenger door sill. I don't think I have ever used my key to get into the trunk. It might not even work after all these years.
07 Boss is offline
post #7 of 25 Old October 1st, 2015, 10:21 PM Thread Starter
AR Stang's Avatar
It is just tap the white/pink wire and run a ground right Boss? I wrote it down a couple weeks ago and am pretty sure that is it.
AR Stang is offline
post #8 of 25 Old October 2nd, 2015, 12:44 AM
Yep. I happen to have a custom factory window switch panel so I just wired mine into the up function on the extra window switch.
07 Boss is offline
post #9 of 25 Old October 3rd, 2015, 10:23 AM
Only time I ever use my key to get into the trunk is when my battery is removed and I ALWAYS forget to pull the parts from my trunk before taking the battery out.
---------- Post added at 09:23 AM ---------- Previous post was at 09:08 AM ----------
And thank you boss for mentioning the junction box, goal for the weekend is to hardwire my radar detector. Was planning to yank out the radio and wire it to that ACC...not that this would be a difficult thing to do, but it's also 95* outside lol.
07 gt, CMS cams, hurst, CAI/tuned, LT's, o/r h, m80's, FRPP mani, UDP, lowered with steeda 1.25/1.5, exedy mach 400/race flywheel, 1-pc DS, BMR upper/lowers, 4.10's, CHE brace with TL's, and a few other things that dont add up to much.
fzr confused is offline
post #10 of 25 Old October 3rd, 2015, 12:31 PM
95*??? That's hot? Wussy. We just got down into the 90's and it feels like heaven. I can't wait till I can actually put my top down and drive around. Another week or so I think.
07 Boss is offline
post #11 of 25 Old October 3rd, 2015, 02:06 PM
Yea but you have a "dry heat" hahaha. It's actually not bad today, I saw the video of the guy with his fnx at the range "melting" so I put mine in my car over night....went out just now (1pm here) and the car is still cool :/
post #12 of 25 Old October 8th, 2015, 04:25 PM
Make Me Squirt
i am ryan's Avatar
WAY easier to use an add-a-fuse for the radar detector. All you'd need to do is remove the sill cover, the SJB cover, and the a-pillar cover.
TORCH RED APPRECIATION CLUB
C&L Racer | Eibach Pro-Kit | BMR LCAs + Relo | BMR PHB | MGW |
GT500 Strut Mounts | Bassanni Axlebacks | OR-H |Tokico D-Spec |
i am ryan is offline
post #13 of 25 Old October 8th, 2015, 05:50 PM
I love to skydive
Durr4456's Avatar
90* and dry is nothin.
MM is awful. Don't ever come here if you haven't been sucked in already!
Durr4456 is offline
post #14 of 25 Old October 8th, 2015, 09:10 PM
FBGM
If you want if you have power to your mirror you can tap off of that I belive. I don't have my radar hooked up there but the backlight for my boost gauge so idk if it will mess with anything.
Saleen SuperCharged, C500 Side Exhaust, Cervinis Ram Air IV Hood, Hurst Short Throw Shifter, Chrome GT500 Replica wheels, GT500 Front Splitter ModBMR 1.25 Lowering Springs, ADJ Panhard Bar, CHE Torque Limiters and K Member Brace
kmac1622 is offline
post #15 of 25 Old October 9th, 2015, 01:19 AM
This is my set up
jlmoto is offline
post #16 of 25 Old October 9th, 2015, 10:51 AM Thread Starter
AR Stang's Avatar
Originally Posted by jlmoto View Post
How is the quality of yours and do you get full field of view with the camera to both sides of the car? If I don't like this image quality of mine I won't install it on the car.
AR Stang is offline
post #17 of 25 Old October 9th, 2015, 10:35 PM
It's good during the day but a little fuzzy at night. But for $30 not bad! Would be better if I was able to angle it down some...
jlmoto is offline
post #18 of 25 Old October 10th, 2015, 04:46 PM Thread Starter
AR Stang's Avatar
That actually is not bad at all. I will stop being lazy and go that route if I don't like my camera's quality.
AR Stang is offline
post #19 of 25 Old October 10th, 2015, 09:11 PM
Yea for the price it's a nice little camera. I have the pioneer bc4 ($180) camera in my truck and it is much clearer picture especially at night but it was also a lot more money!
jlmoto is offline
post #20 of 25 Old October 16th, 2015, 12:02 PM
Scott2's Avatar
I went with the recommended camera for my GPS receiver. Works well and does not look to bad.
From a few feet back.
Up close.
Scott2 is offline
