Starting issues - Never experienced intermittent stuff like this - Forums at Modded Mustangs
post #1 of 8 Old October 12th, 2015, 03:02 PM Thread Starter
Backbone
SGT T's Avatar
Typically, when I've had a dead battery, its just plain, well... dead. It takes a jump to get the car to start.
Today, and for the first time, my car wouldn't start. Its an 09, 42000 miles, Manual. Its always been serviced regularly by the dealer and always had a clean bill of health. Mods are minimal, FRPP CAI, Jegs O/R H, Stingers, Bamatuner. I checked the codes, got a slow o2 code, and a OBD on board diagnostics could not complete (or something like that) p1000 code.
The car sat for a week while I was in the field training. I have let it sit for a week at a time with ZERO issues multiple times. Its garaged.
Today, it would start. Did the typical dead battery thing. Interior lights dimmed, starter clicked rapidly, no turnover. Then i would retry. I checked the dome lights, they werent left on. I tried to restart the car. One turnover, two...then dead again.
Try again.. one, two threeturnovers....slowly, then faster until the car fires up. No battery light, gauge shows good voltage. All is well. I pull out of the driveway, drive to the barber shop. No issues. Car runs great.
I get done with a haircut, turn the car on, and same issue.
Slow start, wont turnover, then after several tries... she fires up. EVen knowing its a FI car...i pump the gas...
So like i said...a dead battery usually means no starting and the attempts to start the car or turn the starter usually get worse ending with a completely dead car that wont even click. This works in reverse order.
Oh....and when it does this, the radio resets...another thing that points to a loss in power.
Before i go running around replacing batteries and stuff....any other ideas?
-T
2009 Colorado Red Mustang GT
FRPP Stingers, FRPP 85mm CAI, FRPP 3.73s, FRPP K-Springs, FRPP/GT500 upper strut mounts, Shelby Adjustable Panhard Bar, Tokico Str.t, Shelby CS40, GT/CS Front and Rear Bumpers, GT500 Spoiler, Jegs O/R H, fuzzy dice.
SGT T is offline
post #2 of 8 Old October 12th, 2015, 03:27 PM
Insomniac
BIGCHRISS197's Avatar
Test your battery at each interval. Off. Starting. Running. That will answer a few questions. When my optima was on its way out it experienced a slow death similar to what youre describing.
BIGCHRISS197 is offline
post #3 of 8 Old October 12th, 2015, 03:35 PM Thread Starter
Backbone
SGT T's Avatar
Will do. I am pretty sure its the batt, but when reading on this common issues no one has been able to ID the real cause.
This is an OE battery as well, not optima. Doubt that matters, but should be worth mentioning.
SGT T is offline
post #4 of 8 Old October 12th, 2015, 03:56 PM
Insomniac
Im suprised you got that much time out of the factory battery.
post #5 of 8 Old October 12th, 2015, 03:58 PM
-T
Sounds like your typical dead battery to me.
What issue, having a dead battery? It happens, they just wear out. The more you cycle a battery and the heat it operates in makes them go bad quickly. Replacing it should be the solution.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #6 of 8 Old October 12th, 2015, 04:23 PM
MM's Caller of Bullshit
Destination S197's Avatar
Sounds like a dead cell in the battery. Replace it.
Destination S197 is offline
post #7 of 8 Old November 12th, 2015, 07:55 PM Thread Starter
Backbone
SGT T's Avatar
Sorry I took so long to reply. I practically live in the field.
It was a dead cell. There's no way to diagnose it that I can tell other than recognizing the symptoms. I replaced it.
Now its good to go. Hope this helps people in the future.
SGT T is offline
post #8 of 8 Old November 12th, 2015, 09:03 PM
Bagel_Dog's Avatar
I was going to say I had what you described happen to me once before on my old '96 Camry. I replaced battery but still had same issues, ended up being a bad ground cable.
Glad you found the issue.
Stand your ground, find the strength within and battle on.
Bagel_Dog is offline
