NSR cam write up. - Forums at Modded Mustangs
post #1 of 40 Old May 26th, 2008, 12:09 PM Thread Starter
MM's resident Juice head
07 STROKER's Avatar
NSR cam write up.
Here it is guys. This is a write up instaling NSR Comp stage 2 cams in a 2007 Mustang GT. Let me tell you guys somthing right off the bat. If you are not well versed with hand tools and have alot of patience, stop reading now and take your car to a shop. This instal takes patience. I gaurante you will not be doing it in 3 hours! It took me 5 and a half...and I was taking my time so I didint mess anything up. I will be showing pics in here but you will have to read to fully understand what you have to do to do this right. So now for all the wrench heads that are still reading this, lets go.
This is what you will need to do the job. Set of cams, Cam phaser bolts (old ones cant be reused because they are torque stretched) and the two Ford specialty tool. One is a timing chain wedge and the other is a valve spring comppresor. I will gwt into how to use these in a bit. You should also have a torque wrench that reads both foot and inch pounds...and some lube...I used motor oil.
Go ahead and unhook the coil on plugs and the fuel injectors...they are just push clips but be gental..i have broke two so far by switching spark plugs. Once they are unhooked remove the coil on plug, there is one bolt for each. Leave the plugs IN, they dont have to be removed. Once the coils are off remove the cam cover. TIP. Unbolt the oil dipstick, it attaches to the block below the cover. This will make it much easier to remove the cover
Close up of where the dipstick bolts to the block...it is undone in this pic
This is what you should be looking at now.
Now it is time to insert the timing chain wedge (yellow thing on a stick) one side is straight and one side is tapered so look at how the timing chain is running...it is opposite depending on what side you are doing...I started with the drivers or LEFT side first. I also marked the chain and sproket with a marker to make sure i was going to be lined up when reinstalling. MAKE SURE THE WEDGE IS IN TIGHT
Look closley and you an see the wedge inbetween the chain...notice how the top of the chain is rounded.
Mark the chain and sproket now before undoing it from the cam
Now go ahead and remove the cam phaser bolt in the front of the cam...be gental...you dont want to roll the engine doing this...it might loosen the wedge. Once that is done simply slide the spocket off the end of the cam and let it sit there on the chain...other installs show removing the sprocket but it is not needed. It can sit there all together and will make reinstalling easier. Once that is done remove the cam journals. I started at the outside and worked my way in untill i was left with the middle one...there will be tension on the bolts all the way off because the cam i under pressure from the springs so be gental her and work back and forth from to pto bottom bolts to remove it evenly. Once that is done it should look like this.
Now simply lift the cam out of its journals.
Now simply pull of the cam follower which just sit there...they look like roller rockers. KEEP THEM IN ORDER. Also the journals are numbered 1 thru 5 with < arrows like that that represent the front of the engine. Keep an eye on them fro re assembly.
Now you lube up the new cam and install it...leave the followers OUT. put the journals back on in proper order with the arrows facing the front of the engine 1 being closest to the front of the engine. Torque the cam journal caps to 89 Inch pounds. Now rotate the cam so the keyway is lined up with the sprocket and slide it on the cam. DO NOT REMOVE THE WEDGE YET. Now go get your new phaser bolt and screw it in and torque it to 30 foot pounds...then turn it 90 degrees more...this stretch torques the bolt and makes it unusable again. Now the motor is going to try and roll while you are torquing the bolt.I just put a ratchet on the crank bolt and held it from rolling while I torques it. I also marked my phaser bolt with a line after i torqued to 30 so i knew where 90 degrees was.
New cam istalled
Phaser bolt
Notice the white line facing vertical on the bolt
After I torqued it 90 degrees...your done.
Now remove your wedge from the chain...Pull hard it wont want to come easy!
Refer to page 2 for rest of write up.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
07 STROKER is offline
post #2 of 40 Old May 26th, 2008, 12:24 PM
menace07's Avatar
Kick ass write up!
black 07 GT, jlt2 cai, sct2 brenspeed 93 octane tune, UDP's, spydershaft, triax, magnaflow catted x, steeda axleback, bad ass steeda suspension
Stealth GT Twin Turbo System On The Way!!!!!!!
STEEDA SUSPENSION CREW FOUNDER
menace07 is offline
post #3 of 40 Old May 26th, 2008, 12:33 PM
You da man!
'08 STi
'02 Supercharged Harley-Davidson F-150 (Sold)
'05 Mustang GT (Sold)
tribaltek is offline
post #4 of 40 Old May 26th, 2008, 12:41 PM
OK, there is no way I'm doing this myself
'08 STi
post #5 of 40 Old May 26th, 2008, 05:07 PM
06GTMustang89's Avatar
Send a message via AIM to 06GTMustang89
oh come on thats EASY just patience my man...GOOD FUCKING WRITE UP DUDE!!!!
JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more.
06GTMustang89 is offline
post #6 of 40 Old May 26th, 2008, 05:10 PM
Admanistrator
v606er's Avatar
now thats good
MAD Stangs #8
v606er is offline
post #7 of 40 Old May 26th, 2008, 05:11 PM
usafimj's Avatar
I've never done anything that extreme and I think I can do it. Just follow the instructions and read it several times and you'll be golden.
hey 07 Pro, why did you install the cam followers after the cam and cam journals were installed. Is it due to the spring tension
11 5.0-- Airaid CAI, Flowmaster mufflers
07 GT-- Gone But Not Forgotten
Military Crew
E-6
usafimj is offline
post #8 of 40 Old May 26th, 2008, 05:26 PM Thread Starter
07 STROKER's Avatar
yes...if you dont and you mange to get the cam on under tention....you have to line the cam up with the sprocket...which is locked...which means if the cam is off you have to turn it....how do you do that when its under all that tention from the springs...thers no where to put a wrench on them...
post #9 of 40 Old May 26th, 2008, 05:30 PM
usafimj's Avatar
k cool. thanks for answering my question. I think when I do cams I'll be doing it myself.
I'll ask more questions when the time comes...lol
Military Crew
E-6
usafimj is offline
post #10 of 40 Old May 26th, 2008, 05:31 PM Thread Starter
07 STROKER's Avatar
my number is at the bottom of page 2 call me if you need to!
post #11 of 40 Old May 26th, 2008, 05:32 PM
usafimj's Avatar
Thanks. It might not be til later on this yr.
Have the roads dried up. Have you gotten on it yet
Military Crew
E-6
usafimj is offline
post #12 of 40 Old May 26th, 2008, 05:37 PM Thread Starter
07 STROKER's Avatar
i took it out the store yesterday ...it stoped raining but the roads were wet.....shes got stank!! Im at work now so i cant give it a good romp till friday now
post #13 of 40 Old May 26th, 2008, 05:39 PM
usafimj's Avatar
I feel your pain. I haven't driven my stang since May 3rd
Military Crew
E-6
usafimj is offline
post #14 of 40 Old May 26th, 2008, 05:43 PM Thread Starter
07 STROKER's Avatar
ya im just rollin on 15 000 km in two years...well this will be its second summer.
post #15 of 40 Old May 26th, 2008, 05:50 PM
BWAL's Avatar
awesome write up man.. +rep
'65 Fastback
'89 LX 5.0
'90 LX 5.0
'92 LX 5.0
'92 LX 5.0
'97 Cobra
BWAL is offline
post #16 of 40 Old May 26th, 2008, 05:58 PM
Admanistrator
v606er's Avatar
good write up
MAD Stangs #8
v606er is offline
post #17 of 40 Old May 26th, 2008, 06:03 PM
IBEATU
stanglifemike's Avatar
Nice man!! thanks for the write-up
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
stanglifemike is offline
post #18 of 40 Old May 26th, 2008, 06:20 PM Thread Starter
07 STROKER's Avatar
no worries
post #19 of 40 Old May 26th, 2008, 06:20 PM
The Despised Vert
Send a message via Yahoo to 2006greyGT
I guess I am stupid... I read it twice and didn't see where you put the followers back in.. looks like they were in before you installed the phaser bolt????
KB 2.6l 4.9l forged stroker 2 1/2" Exhaust Cloth Top
NUMBER 3 Official member of the "My Car Sucks And No One Likes It But Me" CLUB
2006greyGT is offline
post #20 of 40 Old May 26th, 2008, 06:21 PM Thread Starter
07 STROKER's Avatar
i didint grab any pics of that...but i wrote it up on page 2
LinkBack to this Thread: https://www.moddedmustangs.com/forums/modular-mustangs/72812-nsr-cam-write-up.html
Curious about cam shims | S197 Mustang Forum - S197Forum.com This thread Refback January 2nd, 2018 01:00 PM
Hot Rod cam dyno results - Page 4 - S197 Mustang Forum - S197Forum.com This thread Refback April 6th, 2016 04:23 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source - Ford Mustang Forums This thread Refback December 25th, 2015 07:18 PM
Comp Cams SPR Stage 2 Install.... - SouthFloridaStangs.net This thread Refback April 18th, 2012 02:05 AM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source - Ford Mustang Forums This thread Refback November 3rd, 2010 12:44 AM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source - Ford Mustang Forums This thread Refback August 8th, 2010 09:22 PM
S197 Sites This thread Refback April 28th, 2010 11:22 PM
FRPP hot rod cams and nitrous..? - WWW.S197FORUM.COM This thread Refback March 10th, 2010 12:40 AM
Curious about cam shims - WWW.S197FORUM.COM This thread Refback February 23rd, 2010 12:02 PM
Hot Rod cam dyno results - Page 4 - WWW.S197FORUM.COM This thread Refback February 9th, 2010 07:08 PM
HELP: Cam Tools - WWW.S197FORUM.COM This thread Refback December 16th, 2009 05:52 PM
HELP: Cam Tools - WWW.S197FORUM.COM This thread Refback December 16th, 2009 05:41 PM
Curious about cam shims - WWW.S197FORUM.COM This thread Refback November 10th, 2009 09:34 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source This thread Refback September 9th, 2009 07:25 AM
Comp Cams SPR Stage 2 Install.... - SouthFloridaStangs.net This thread Refback June 29th, 2009 08:15 PM
How hard - MustangForums.com This thread Refback April 8th, 2009 02:47 AM
Cams & Headers for 4793 - Page 2 - IMBOC This thread Refback March 31st, 2009 10:03 AM
How hard - MustangForums.com This thread Refback September 21st, 2008 07:22 PM
My review of JDM: - Page 2 - WWW.S197FORUM.COM This thread Refback August 12th, 2008 04:10 PM
My review of JDM: - Page 2 - WWW.S197FORUM.COM This thread Refback August 12th, 2008 03:51 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source Forums This thread Refback June 14th, 2008 04:42 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source Forums This thread Refback June 12th, 2008 07:52 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source Forums This thread Refback June 9th, 2008 10:00 AM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source Forums This thread Refback June 8th, 2008 10:55 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source Forums This thread Refback June 8th, 2008 10:15 PM
