The official 4.2 swap post - Forums at Modded Mustangs
post #1 of 2 Old April 3rd, 2012, 12:59 AM Thread Starter
Raging Mad Motherfucker
The Cheeks McDuke's Avatar
DISCLAIMER: In no way am I trying to take credit for writing this.These are the writings of PETE from V6Power. I am merely reposting for everyone's general fund of knowledge due to the many people asking. The original thread can be viewed here: The official 4.2 swap post - V6Power Messageboard
I can't remember there ever being a truly accurate 4.2 post so here goes...
Early 97-98 4.2s had a 2-pc main girdle that connected the 1st to the 2nd main cap and the 3rd to the 4th main cap and had larger main bolts. Mid-1998 and up 4.2s used a 1-pc girdle that only connected the rear 3 main caps and had smaller main bolts.
To use the early 4.2 in any Mustang will require replacing the girdle with a newer 3 main style from a 4.2, get a 99-up 3.8 girdle or just delete it. You will also have to cut the girdle studs sticking out of the head of the main bolts on the 1st main bearing. The 99-00 3.8s used a factory windage tray/girdle that is better than nothing but certainly not ideal. The 01-up 3.8s use the same windage tray/girdle as the 4.2.
Late 00 3.8s are actually early 01 spec engines that are internally balanced. If you have one of these.....just use the notes for an 01-up.
94-98 Single port heads
- 4.2 shortblock
- Single port heads/fuel rail/intake
- Mustang 3.8 water pump
- Auto trans = 4.2 or 01-up flexplate
- 5spd = 01-up or rebalanced 3.8 (0 or neutral) flywheel and a pilot bearing
- Re-use your stock cam position sensor
- 01-up 3.8 oil pan
- 01-up 3.8 oil pick-up tube and screen
- 4.2 damper or 01-up 3.8 damper (use the 01 pulley for blower cars)
- Re-use the stock 3.8 oil pressure sender and tube
- Re-use the Mustang headers
- You can use the 4.2 or 3.8 dipstick. Just keep track of where 5 qts puts the mark when refilling with oil.
94-98 Split port heads
*** You will need to perform all the mods required for a split port conversion plus these steps for the 4.2 (see pbmilan or V6sprout for the video) ***
- 4.2 shortblock or longblock
- You can use the 4.2 heads
- Mustang upper and lower intake
- Custom return style fuel rail (VMP has them)
- 01-up 3.8 oil pan
99-00 split port heads
- Mustang upper and lower intake and fuel rail
- 01-up 3.8 oil pan
01-up split port heads
- Auto trans = your stock flexplate
- 5spd = your stock flywheel and a pilot bearing
- Your 01-up 3.8 oil pan
- Your 01-up 3.8 oil pick-up tube and screen
- Your stcok 01-up 3.8 damper
If you cannot seem to spell simple 4 letter words, use some semblance of punctuation when forming sentences, or SpElL N tAlK LiEk ThIs, I'm going to assume you know nothing and are retarded.
The Sixxer is Dead. 94-95GT in the works.
The Cheeks McDuke is offline
post #2 of 2 Old August 2nd, 2013, 08:56 PM
96-GT_Josh's Avatar
Quick question. My wife's stang is a 00.
If I buy a 97-98 4.2 block, with pulley and oil pan/pickup, what else would I need?
I would be using her top end, also her accessories.
Do I need to swap pans and pickups still? Why is switching pans and pickups necessary?
Do I need to switch crank pulleys? Her is a externally balance 3.8 but the flywheel isn't balance and has no wobble.
Also would all the accessories bolt to the block to make it a quick swap?
Why is switching parts off a 01+ v6 needed and the 99-00 parts can't be used?
And last question. What year 4.2 block would be best to buy? And the easiest swap?
96-GT_JOSH
I'D RATHER PUSH MY FORD THAN DRIVE YOUR CHEVY
MM COBRA CLUB #124
96-GT_Josh is offline
