4.3 Turbo Stroker Build - Forums at Modded Mustangs
post #1 of 118 Old June 21st, 2012, 10:04 PM Thread Starter
JTs03v6's Avatar
Going to build this motor pretty soon but dont know who I should let build it. ssm, dave dalke, gss, pro engine 4miles from the house. Not going back to precision engine.
Shooting for 650hp, mid 9's 1/4 or low 6's 1/8th, 2800lb chasis, 6765 billet turbo, thinking a 218/218 cam will be plenty plus be easy to tune and keep the back pressure to a minimum.
Who should I get to build this motor and machine the block?
Turbo 4.3 stroker, 6.73 @ 106mph...still tuning
https://moddedmustangs.com/forums/v6-...ker-build.html
JTs03v6 is offline
post #2 of 118 Old June 21st, 2012, 10:16 PM
may as well let ssms do it....
You also may need more cam.
[CENTER][IMG]http://imageshack.us/a/img839/792/esg642t.png[/IMG][/center]
[CENTER]Hi, You can call me Kyle
[COLOR="Red"][SIZE="2"]Random ESG fact: Had a prochamber on his v6 before it was popular.[/SIZE][/COLOR][/CENTER]
ESG-642T is offline
post #3 of 118 Old June 21st, 2012, 10:41 PM Thread Starter
JTs03v6's Avatar
I'd like for him to do it but his mark up is so damn high from the machine shop. Maybe if he can be a little more competiative I'd let him do it.
JTs03v6 is offline
post #4 of 118 Old June 22nd, 2012, 12:53 AM
I agree with you on SSMS. Great guy but the mark up is to much for me as well.
V6 swap to 347 Stroker
http://youtu.be/Bmb8YshZlqw
SleepV6CR is offline
post #5 of 118 Old June 22nd, 2012, 01:36 AM
davidcseifert's Avatar
I would avoid GSS, you'll end up with JB weld in the block somewhere...
BV heads, P&P lower, comp 218/226 cam, 4.2, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, Xcal2 Ortiz 93 tune, Windstar, 8.8 w/ 3.73's, SFC's, MM LCA's, cut springs, kyb shocks/struts
davidcseifert is offline
post #6 of 118 Old June 22nd, 2012, 07:01 PM Thread Starter
JTs03v6's Avatar
Why do you say Tom would use jb weld in a built short block? They did one hell of a job on henry's (I think his name is) car.
Either way, think I'm going to go with dd. His price is about the best, he has all the tools to build,balance,blueprint this motor. I trust his work as much as ssm because he has been doing this for a very long time.
Next up, what cam should i be looking at...
Looking to make peak power between 6000-6500 rpm but I want to take full advantage of this smaller compressor in the low 5000rpm range.
JTs03v6 is offline
post #7 of 118 Old June 22nd, 2012, 08:55 PM
Because, his heads from tom had jb weld
ESG-642T is offline
post #8 of 118 Old June 23rd, 2012, 09:50 AM
99 BLUE V6's Avatar
JT I could help you out some. If you research freight you could probably get a good deal from - freight quote.com
pm when your close to ready
99 BLUE V6 is offline
post #9 of 118 Old June 23rd, 2012, 02:57 PM
I think I would let this guy help you out.
ESG-642T is offline
post #10 of 118 Old June 23rd, 2012, 07:09 PM Thread Starter
JTs03v6's Avatar
Will do bruce. btw...thats an amazing shop you guys have down there. When I walked into my local machine shop...oh lawd!!! lol, clutter fuck would be the closest to describing it.
JTs03v6 is offline
post #11 of 118 Old June 27th, 2012, 12:07 AM
^^^ this.... and the second (current ones) have a weld that cracked... so yeah no one will ever get a good rep about them from me
post #12 of 118 Old June 27th, 2012, 07:38 AM
99 BLUE V6's Avatar
Time to chop up a old head on bandsaw and take a good look. Are these brake through's all in the same spot?
post #13 of 118 Old June 27th, 2012, 11:17 PM Thread Starter
JTs03v6's Avatar
Cam specs are remaining secret
JTs03v6 is offline
post #14 of 118 Old June 28th, 2012, 12:30 AM
224 228 114 580 call for a good time
If those are cam specs, they are mediocre at best
ESG-642T is offline
post #15 of 118 Old June 28th, 2012, 02:48 PM Thread Starter
JTs03v6's Avatar
Nothing about this build is mediocre.
JTs03v6 is offline
post #16 of 118 Old June 28th, 2012, 05:22 PM
You want to run 9s lol
ESG-642T is offline
post #17 of 118 Old June 28th, 2012, 10:01 PM Thread Starter
JTs03v6's Avatar
I could probablly squeeze 140mph out of this compressor. May drop the coin on a 72gtq down the road but dont want to go much bigger than that. I'm building for high rpm so we'll see if the 67mm can keep up.
Bruce, what are your thoughts on a morana main girdle? I remember a post ron talked about a discussion with arp about the clamping force and sacraficing stud strengh because the nut is further down on the stud.
JTs03v6 is offline
post #18 of 118 Old June 29th, 2012, 08:17 PM Thread Starter
JTs03v6's Avatar
Hmm, stock rockers are only good to .560 lift. Time for some roller rockers.
JTs03v6 is offline
post #19 of 118 Old July 6th, 2012, 07:03 PM Thread Starter
JTs03v6's Avatar
Change of plans. Going with aftermarket valves so we can get more lift. Cam specs have been modified.
JTs03v6 is offline
post #20 of 118 Old July 6th, 2012, 07:15 PM
so whats the story now?
ESG-642T is offline
