p1336 - Forums at Modded Mustangs
post #1 of 13 Old August 14th, 2012, 05:59 PM Thread Starter
:shiftyeyes
xi KRON1C ix's Avatar
p1336
So leaving work today, my car threw the code p1336. Whats going on?
xi KRON1C ix is offline
post #2 of 13 Old August 14th, 2012, 06:11 PM
GreenShift's Avatar
Done a cam swap? Teh interwebs says the cam might be out of sync with the cam position sensor.
GreenShift is offline
post #3 of 13 Old August 14th, 2012, 06:16 PM Thread Starter
:shiftyeyes
replaced the cam shaft sync and sensor bout 4 months ago
i googled it and took it to auto zone to see what the code was, everything is saying cam shaft sync / sensor. could it really go out that quick?
post #4 of 13 Old August 14th, 2012, 06:40 PM Thread Starter
:shiftyeyes
just talked to my mechanic he said I need a KAM reset. Do i need to use a sensor for this or can i reset it manually?
post #5 of 13 Old August 14th, 2012, 06:45 PM
GreenShift's Avatar
Maybe ESG or Mike will make an appearance, they know more about that stuff than I ever will
post #6 of 13 Old August 14th, 2012, 06:54 PM Thread Starter
:shiftyeyes
cool, thanks anyway bud
post #7 of 13 Old August 14th, 2012, 07:03 PM
bigjohnstud4200's Avatar
If you have a tuner, you can clear the KAM (Keep Alive Memory).. or you can disconnect the battery for 20 minutes.
Tuned by [email protected]
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #8 of 13 Old August 15th, 2012, 10:32 AM
V6 BIOTCH
mustangmike!'s Avatar
fuck your gonna make me look this shit up
mustangmike! is offline
post #9 of 13 Old August 15th, 2012, 10:36 AM
V6 BIOTCH
P1336 - Crankshaft/Camshaft Sensor Range/Performance
Description: The input signal to the powertrain control module (PCM) from the crankshaft position (CKP)
sensor or the camshaft position (CMP) sensor is erratic.
Possible Causes: • Damaged CKP sensor
• Damaged CMP sensor
• Base engine concerns
• Harness concerns
Diagnostic Aids: Check the harness for routing, alterations, improper shielding, or electrical interference from
other improperly functioning systems.
Application Key On Engine Off Key On Engine Running Continuous Memory
All — — GO to Pinpoint Test JD.
post #10 of 13 Old August 15th, 2012, 10:37 AM
V6 BIOTCH
check your plugs on both crank and cam sensor.
My cam sensor plug isn't the right right, so It likes to slide up and fuck up the signal. So I taped da fuhq out of that thing
Damn race car to fast to keep a fucking plug on its cam sensor -_-
post #11 of 13 Old August 15th, 2012, 11:09 AM
P1336 means your car is almost 1337. It just needs a little more work.
Skargon is offline
post #12 of 13 Old August 15th, 2012, 12:02 PM
Fee Fie Foe Fum
gaetz1985's Avatar
iTrader: 5 reviews
World's First M112 Singleport Essex
gaetz1985 is offline
post #13 of 13 Old August 15th, 2012, 04:12 PM Thread Starter
:shiftyeyes
Possible Causes: Damaged CKP sensor
Damaged CMP sensor
Harness concerns
All GO to Pinpoint Test JD.
Thanks mike, reps when i get to a computer
LinkBack to this Thread: https://www.moddedmustangs.com/forums/v6-mustangs/273247-p1336.html
p1336 ford mustang This thread Refback May 2nd, 2015 02:50 AM
What does p1336 mean - 1Q5A This thread Refback August 10th, 2014 12:29 PM
