2007 Mustang Help - Forums at Modded Mustangs
post #1 of 18 Old October 2nd, 2012, 11:08 PM Thread Starter
2007 Mustang Help
Hello everyone i just recently joined the site and was curious if i buy a BBK 70 mm throttle body from AM should I also get the throttle body spacer and if so what is the hp increase already have CAI with 91 octane tune
mudder mustang is offline
post #2 of 18 Old October 3rd, 2012, 07:32 PM
iTrader: 13 reviews
imo you're wasting your money
SON1C is offline
post #3 of 18 Old October 3rd, 2012, 07:44 PM
Not A Regular Member
I'm not well schooled on the 4.0L engines but I would have to assume that a throttle body upgrade is a waste of time and money without some sort of FI (nitrous, turbo, supercharger).
McQueen is offline
post #4 of 18 Old October 4th, 2012, 06:39 PM
T-Money's Avatar
the throttle body spacer wont do anything. the throttle body might give you a couple of hp but not enough to justify spending 300 bucks
1993 Mazda MX-6 LS: Mods-KLZE motor swap, stainless steel headers, ported intake manifold, alum. underdrive pulley, chipped and tuned, intake, 2.5" exhaust with cat delete, tokico illumnas w/eibachs, Full build coming soon...
T-Money is offline
post #5 of 18 Old October 4th, 2012, 09:24 PM
IG: opiesvt
watson's Avatar
I thought I replied on this last time I saw it. A 70mm TB is overkill. If you still plan on getting it, the spacer is needed if you want to keep the plastic piece on top of the engine there without cutting into it.
MM COBRA CLUB MEMBER #134
watson is offline
post #6 of 18 Old October 5th, 2012, 09:21 AM
Admanistrator
v606er's Avatar
Spend your money elsewhere, such as on gears and tlok.
MAD Stangs #8
v606er is offline
post #7 of 18 Old October 5th, 2012, 09:32 AM
iTrader: 13 reviews
SON1C is offline
post #8 of 18 Old October 6th, 2012, 09:13 PM Thread Starter
Thanks for all of the responses so my next question is what should be the next upgrade already have CAI and 91 octane tune but curious whats going to give me the best bang for my buck, Thanks again
post #9 of 18 Old October 6th, 2012, 09:16 PM
iTrader: 13 reviews
gears and tlok is what the majority of people will say 373 or 410s
SON1C is offline
post #10 of 18 Old October 6th, 2012, 09:24 PM Thread Starter
what r the benefits of gears and t lok and which ratio should i go with?
post #11 of 18 Old October 6th, 2012, 09:30 PM
3.73 if a manual, 4.10 if an auto. Stiffer gears give your vehicle a mechanical advantage for accelerating, while losing top end speed. you'll get better mileage in the city and worse on the highway. The reduction of your top speed is negligable considering you probably won't be getting up that high anyway.
A t-lok drives both tires whereas a sixxer comes stock with 'one tire fire'. driving two wheels is better than driving one. more traction, safer in the elements etc.
4.0 V6
Vortech, Custom Big-Bore Intake, Custom Driveshaft, Stage 3+ Methanol, Koni Yellows and K-Springs, 4 Piston Brembos, 8.8 with 3.73s, Custom Longtube headers and custom exhaust
417 RWHP
392 ft/lbs Torque
In the hunt for 11's
ejschmidt is offline
post #12 of 18 Old October 6th, 2012, 09:40 PM Thread Starter
ejschmidt what would u say is the next best upgrade to my sixer
post #13 of 18 Old October 6th, 2012, 09:44 PM
IG: opiesvt
watson's Avatar
^Indeed
Performance-wise, you can go with ignition parts but when you're serious about making it go faster, I recommend getting a turbo or something...they're not that expensive nowadays.
Don't waste your time or money on countless bolt-ons when you can just save for something that'll make a real difference. Trust me, don't get to the point where you've spent thousands on parts here n there and look back thinking "man, I coulda got a killer turbo setup a long time ago"
Also, certain suspension mods can help with going faster. Just because they don't have "horsepower" in the description, that doesn't mean they won't help.
Just my .02
watson is offline
post #14 of 18 Old October 6th, 2012, 09:48 PM
IG: opiesvt
watson's Avatar
If you're on a budget, racing stripes, projector headlights, and decals will all give you nice gains in the "go fast" department.
watson is offline
post #15 of 18 Old October 6th, 2012, 10:01 PM
TPowers6's Avatar
Originally Posted by LethalDosage View Post
^Indeed
Just my .02
i agree with the turbo, well worth the investment
TPowers6 is offline
post #16 of 18 Old October 6th, 2012, 10:07 PM
IG: opiesvt
watson's Avatar
And how are YOU so sure of this?
watson is offline
post #17 of 18 Old October 6th, 2012, 10:12 PM
TPowers6's Avatar
I have seen one before, they look fast
TPowers6 is offline
post #18 of 18 Old October 7th, 2012, 11:29 PM
I decided to supercharge my sixer. Obviously I'm pleased with the decision to do so. I paid a good amount for it, but then again, I can afford these sorts of things. The best part is that I now easily smoke 4.6L and 5.0L v8s at the track regularly.
What you have to keep in mind is the synergistic effect of upgrades. Yes, a new exhaust will run 15 (let's say) standalone horsepower and a CAI can do 15hp as well, but together you might be able to get out 35 hp instead of 30 hp.
I recommend getting an 8.8 rear end from a GT mustang if you want to upgrade to some serious horsepower. If you don't plan to do forced induction then I'd suggest just sticking to maybe a T-Lok and some stiffer gears.
4.0 V6
417 RWHP
392 ft/lbs Torque
