In reverse it has a stall.. - Forums at Modded Mustangs
post #1 of 44 Old September 14th, 2013, 01:28 AM Thread Starter
hi you can call me mater
03 cristian's Avatar
iTrader: 5 reviews
Whenever I try to go in reverse the car has to absolutely build up to 1500+ rpm in order to move. I have a jmod but thats it....
When I said in a previous post that I had a stall I meant that I also have to build up to 1500 to move the car at all. And when i'm WOT the car will take a little longer than usual to reach redline. its not spark related its tranny related I know for sure, any one have any suggestions?
"I wonder if I sprayed some on my junk, I could go raw dog and not get herpes. But first I'd have to find a female willing to have relations."-kmac1622
03 cristian is offline
post #2 of 44 Old September 14th, 2013, 11:36 AM Thread Starter
iTrader: 5 reviews
Anyone
post #3 of 44 Old September 14th, 2013, 11:57 AM
JTs03v6's Avatar
Need to datalog it. rpm, tps, vehicle speed, actual slip across converter, command gear, tv pressure, etc... If the j-mod was done correctly it should snap into reverse. You may need some recalibration done to the tuning software.
Turbo 4.3 stroker, 6.73 @ 106mph...still tuning
https://moddedmustangs.com/forums/v6-...ker-build.html
JTs03v6 is offline
post #4 of 44 Old September 14th, 2013, 12:00 PM
iTrader: 5 reviews
fluid and filter in tranny checked lately?
M112 IN 2016
LT's on 2.5" MAC, 3.73 trac loc, M112
PARTS FOR SALE MAKE OFFERS - PM PLEASE
warthogdriver is offline
post #5 of 44 Old September 14th, 2013, 12:12 PM Thread Starter
iTrader: 5 reviews
Thats less than 1000 miles old
---------- Post added at 12:12 PM ---------- Previous post was at 12:11 PM ----------
Can you please list everything I need to datalog? Cause you said etc..
post #6 of 44 Old September 14th, 2013, 12:17 PM
M112'd Sixxer
Sounds like more atf needs to be added.
Garage:
1999 Mustang V6 M112 4R70W (Elise) Sponsored by Ortiz Performance
2013 Fiat 500 Turbo C510 (Rosso Rocket)
Fink is offline
post #7 of 44 Old September 14th, 2013, 02:10 PM Thread Starter
iTrader: 5 reviews
Ill add some in a bit
---------- Post added at 02:10 PM ---------- Previous post was at 01:54 PM ----------
Does anyone know how to describe the smell of good ATF. I can only describe it as it smells like eggs.
post #8 of 44 Old September 14th, 2013, 02:41 PM
M112'd Sixxer
do you have a bottle of new ATF? smell bottle, compared.
personally, atf has no smell.
Garage:
Fink is offline
post #9 of 44 Old September 14th, 2013, 03:07 PM Thread Starter
iTrader: 5 reviews
Well damn the new atf bottle smells the same as my Tranny fluid.
post #10 of 44 Old September 14th, 2013, 03:12 PM
M112'd Sixxer
then it should be good.
i was just saying that i dont smell anything when i smell atf. even gear oil isnt that bad to me.
Garage:
Fink is offline
post #11 of 44 Old September 14th, 2013, 03:40 PM
iTrader: 5 reviews
tranny fluid is mostly pretty subtle...my wives grand cherokee takes that ATF+4...that stuff smells burnt coming outta the bottle, strong crap
M112 IN 2016
post #12 of 44 Old September 14th, 2013, 11:09 PM Thread Starter
iTrader: 5 reviews
I'll be datalogging tomorrow and sending it to Ortiz performance if he suggest that my converter is done,I have an excuse to get a 3200 stall.
post #13 of 44 Old September 15th, 2013, 12:35 PM
M112'd Sixxer
Did you addd atf?
You should never have to rev your car up for it to move if there is the right amount of oil with a stock TC. Unless by some unforeseen event your pump died, but then it should not work at all and make horrible noises.
When i sold my f150, took a little more rpms than normal for it to move. Checked atf and it was low, put 2 liters in and sold the truck 1 hr later.
Garage:
Fink is offline
post #14 of 44 Old September 15th, 2013, 12:48 PM Thread Starter
iTrader: 5 reviews
Did you addd atf?
What would a dead pump sound like?
post #15 of 44 Old September 15th, 2013, 01:03 PM
M112'd Sixxer
from my past experience, metal on metal grinding.
Garage:
Fink is offline
post #16 of 44 Old September 15th, 2013, 01:03 PM
iTrader: 5 reviews
You can check the pump by taking one cooler line off and getting a bucket...start her up.
If the line pumps out into bucket then it works. Do it fast...the pump moves alot of fluid quickly.
M112 IN 2016
post #17 of 44 Old September 15th, 2013, 01:15 PM Thread Starter
iTrader: 5 reviews
Oh shit thats what my car has been.sounding like for a year....
Sounds like there is metal on metal grinding when under load
---------- Post added at 01:15 PM ---------- Previous post was at 01:14 PM ----------
Can you give me a link or picture of where an easy accessible cooler line is?
post #18 of 44 Old September 15th, 2013, 01:27 PM
M112'd Sixxer
your rad has 2 on the DS.. or under the xar on the trans. passenger side, 13mm line wrench.
Garage:
Fink is offline
post #19 of 44 Old September 15th, 2013, 09:52 PM Thread Starter
iTrader: 5 reviews
ok so quick update I have added 3 full quarts and it reads full. when I put it in reverse I still have to climb to about 1600 rpm now. and when in reverse If I 35% throttle it, it will stall until 1500 and jump out of the hole like a bat from hell. but after the 2000rpm mark it will take a while to reach 6100rpm which is my redline set by Ortiz Performance,but the car feels sluggish like if its heavy as a tank.. I still haven't datalogged due to me being away from home and I forgot my usb cable. Does anyone know what the heck burnt tranny fluid smells like? I guess I just have to wait until I get home to datalog and check to see if my transmission pump is done with, but I have a question will a transmission with an effed up pump still run?
post #20 of 44 Old September 15th, 2013, 10:47 PM
iTrader: 5 reviews
no, if your pump stops you will to.
had a pump go out before, your dead in the water.
M112 IN 2016
