General Information
Year
2001
Make
Ford
Model
Mustang
Engine:
Aluminum Block Bored .020” over
Manley Forged Pistons (10.5:1CR)
Forged Cobra Crank
Manley H Beam Rods
Federal Mogul Main & Rod Bearings
ARP 2000 Hardware
Cobra Oil Pump
Billet Oil Pump Gears
Patriot Performance Stage 3 Heads
Comp Cams (Custom Grind from Modular Powerhouse)
Built by Tim Lynch @ Proline Race Engines
Transmission:
McLeod Super Heavy Duty Clutch
Pro 5.0 Shifter
UPR Triple Hook Quadrant
UPR Firewall Adjuster
Driveshaft Loop
Rear End:
Eaton Posi
Moser Axles (31 spline)
FRPP 4.10 Gears
Welded Axle Tubes
Air & Fuel:
Nitrous Express
30# Injectors
BBK 75mm Throttle Body
Trick Flow Plenum
K&N Air Filter
03+ Cobra Tank & Pumps
Exhaust:
Mac Long Tube Headers
Mac Off Road H-Pipe
Magnaflow Stainless Steel Catback
Cutouts
Suspension:
4 Cylinder Front Springs (cut)
Lakewood 90/10 Drag Struts
FRPP “C” Springs (cut)
Tokico Shocks
Steeda C&C Plates
Kenny Brown Full Length Subframe Connectors (bolted & welded)
UPR Solid Lower Control Arms
UPR Double Adjustable Control Arms
Welded Torque Boxes
Rims & Tires:
Deep Dish Bullitt Wheels (street)
17x10 ½ & 17x9
315/35-17 Nitto Drag Radials
275/40-17 Sumitomo
Weld Pro Stars (strip)
15X8 & 15x3 ½
28x9 M/T ET Drag
Skinnies (front)
Misc.:
Mac White Face Gauges
Raptor Shift Light
MSD Window Switch
NX Gen X 2 Safety Kit
Goal: 12.0 @ 112mph NA & 10.9's @ 124mph on N2O
Forged Cobra Crank
Manley H Beam Rods
ARP 2000 Hardware
Cobra Oil Pump
Transmission:
Pro 5.0 Shifter
Driveshaft Loop
Rear End:
Eaton Posi
FRPP 4.10 Gears
Welded Axle Tubes
Air & Fuel:
Nitrous Express
30# Injectors
Trick Flow Plenum
K&N Air Filter
Exhaust:
Mac Off Road H-Pipe
Cutouts
Suspension:
Tokico Shocks
Steeda C&C Plates
Welded Torque Boxes
Rims & Tires:
17x10 ½ & 17x9
275/40-17 Sumitomo
15X8 & 15x3 ½
28x9 M/T ET Drag
Skinnies (front)
Misc.:
Raptor Shift Light
MSD Window Switch
