General Information
Year
2001
Make
Ford
Model
Mustang GT
Stock block was stroked to 5.0L using an Eagle crank and connecting rods. Compression was set to 9.6:1 from a set of Diamond pistons. Patriot stage 2 heads with comp cam 270ex cams. feeding it is a bbk cold air intake, into an accufab 70mm throttle body/plenum with ~24 psi ford racing injectors. its got bbk shorty headers with an off road pypes x pipe. magnaflow magnapack mufflers that are dumped at rear axle. its got a new spec stage 2 clutch with the steeda adjustable clutch cable. the transmittion is the Tremec 3650 with the steeda short throw shifter. rear end is geared to 3.73. Also has a tubular k member and H&R ss springs.
