General Information
Year
1997
Make
Ford
Model
Mustang Cobra
Suspension :
UPR Tubular K-Member
UPR Tubular A-Arms
UPR Coil over Sleeves
Ground Pounder 12-200 Coil Over Springs
Steeda Caster Camber Plates
KYB Sport Shocks and Struts
UPR Double Adjustable Upper Control Arms with Hyme Joints
UPR Single Adjustable Lower Control Arms with Hyme Joints
Performance :
Precision 61mm Turbo
Tial 38mm Wastegate
3" Core Intercooler
Power By The Hour custom Turbo Kit
Flowmaster Y-Pipe
Magnaflow Catback
Ford Racing 3.55 Gears
UPR Blue Thunder Short Throw Shifter
UPR Battery Relocation Kit
Fuel System :
Walbro 255 In Tank Pump
Walbro 255 In Line Pump
UPR In Line Fuel Filter
UPR Fuel Rails
Mallory Fuel Pressure Regulator
-8 Fuel Feed Line
-6 Fuel Return Line
Lucas 38lb/hr injectors
Interior :
Autometer Phantom Mechanical 0-35psi Boost Gauge
Autometer Phantom Electronic 0-100psi Fuel Pressure Gauge
Speed-of-Sound Gauge Pillar
UPR Satin Window Switch Kit
UPR Satin Shifter Bezel
UPR Satin E-Brake Handle
UPR Composite Shift Knob
Exterior :
Wheel Replica 03 Cobra Wheels painted Black
Saleen S281 Wing
Mustang JDM Style Headlights w/Black Housings
Under Hood :
Custom Powder Coated Intake, Timing Cover and Valve Covers
UPR Polished Radiator Cover
UPR Polished Spark Plug Covers
UPR Satin Cobra-Engraved Intake Emblem
PBH Custom Coil Pack Bracket
Waiting for Installation (Currently in Possession) :
Teksid Aluminum Block (Bore 30 Over)
Cobra Steel Crank
Manley H-Beam Rods
Manley Flat Top Pistons (11.1 compression)
4R70W
I'm sure there is more I am missing!
UPR Tubular A-Arms
Performance :
Tial 38mm Wastegate
3" Core Intercooler
Flowmaster Y-Pipe
Magnaflow Catback
Fuel System :
UPR Fuel Rails
-8 Fuel Feed Line
-6 Fuel Return Line
Interior :
Exterior :
Saleen S281 Wing
Under Hood :
Cobra Steel Crank
Manley H-Beam Rods
4R70W
