General Information
Year
2002
Make
Ford
Model
Mustang GT
Motor:
on3 70mm forward facing kit
60# injectors
BBK 78mm Throttle body
'05 slot style MAF
Moroso dual fan
Flow Master cats
240amp alternator
Snow performance stage 2 MAF methanol kit
Oil filter relocation kit
MMR I beam Rods
MMR billet oil pump gears
MMR Stage 3 turbo cams
Manley Notched pistons
Manley Valve spring kit
Comp cam gears
Edlebrock Intake Manifold
4v Oil pump
Fully built slushbox
Edge Racing torque converter
Looks:
Saleen Spoiler and rear bumper
Boxed and welded engine bay
Shaved door handles
2010 GT wheels
Mososo brake tank cover
Moroso powersteeling tank
Canton radiator overflow tank
Rear seat delete
Extras:
Walbro 290lph fuel pump
Battery relocation kit
MSD 2-step
Urathane motor mounts
UPR k-member
UPR upper/lower contol arms
UPR srings/ coil
Cobra brakes
4.10 gears
8.8 rear end cover upgrade
Kenne Bell subframe connectors
6pt roll cage
Weld racing track wheels with hoosier DR's
Driveshaft catch
Aluminum Driveshaft
Line lock
Autometer boost,a/f, oil press, trans temp gauges
60# injectors
'05 slot style MAF
Moroso dual fan
Flow Master cats
240amp alternator
MMR I beam Rods
Comp cam gears
4v Oil pump
Looks:
Shaved door handles
2010 GT wheels
Rear seat delete
Extras:
MSD 2-step
UPR k-member
UPR srings/ coil
Cobra brakes
4.10 gears
6pt roll cage
Driveshaft catch
Aluminum Driveshaft
Line lock
