General Information
Year
2005
Make
Ford
Model
Mustang GT
Modular Performance 326 Big Bore
Custom Twin 67mm Turbo Kit being built with 67mm Comp Turbos
CG Fabrication Forward Facing 1 3/4" Turbo Headers
Custom JPC Intake Manifold with Monoblade Throttlebody
SCT BA5000 "Big Air" Mass Air Sensor
Livernois Stage 3 Heads-- 5 Axis CNC Machined, +1mm Oversized Valves,
300 cfm Intake Flow and 215 cfm Exhaust Flow
Custom L&M Cams
BBR VCT Lock out Sprockets
Full Magnafuel System
83lbs FRPP Fuel Injectors
Home Made PCV Delete with K&N Filters
FB Performance 4STB-E Transmission with 4500 Stall Multi Disk Lock Up Converter and Overdrive
Currie 9"-4.11 gears, Detroit Locker, and Moser Gun Drilled Axles
BMR Race Lower Control Arms - Rod Eye x Rod Eye
BMR Race Upper Control Arm - Rod Eye
BMR Extreme Anti Roll Bar
BMR Boxed Subframe Connectors
BMR Tubular K Member
BMR Front Sway Bar Delete
Steeda Ultralite Lowering Springs on Front, Afco inbound mounted Coil Overs in rear attached to cage
Mad Man Racing Custom 10 point Chromoly Roll Cage
Bogart D-10 Billet Wheels 15 x 4.5 and 15 x 10
RotorPros Drilled and Slotted Rotors with Hawk Pads
Custom L&M Cams
