General Information
Year
1995
Make
Ford
Model
Mustang GT
Pro Charger D-1SC w/ 3.55-inch pulley, 4 pounds of boost Pro Charger 3 core intercooler, Cylinder Heads Trick Flow Twisted Wedge 170cc, 2.020 in./1.600 in. valves, Comp Cam 1.6 roller rockers, Intake Manifold Trick Flow Street Burner, Trick Flow EFI Heat Spacer Mass Air Trick Flow 75mm, Throttle Body BBK 75mm
Fuel System BBK 255-lph fuel pump, 42-lb/hr injectors; BBK adjustable fuel pressure regulator, Pro Charger fuel pressure regulator, Fluidyne aluminum 2 row radiator, BBK short equal length headers, Flow Master cat back 40 series mufflers, SPEC Stage III dual friction clutch , Ford Racing aluminum driveshaft, Steeda Auto sports Tri-Ax shifter, 3.73 gears
Comments
There are no comments to display.
