Showcase cover image for 07 STROKER's 07 Mustang GT 5 speed
General Information
Year
07
Make
Mustang
Model
GT 5 speed
Livernois 298 stroker
Livernois stage 3 heads
T56 Magnum XL six speed transmission
MSD 2 step
410 Gears
Eton TruTrac
Dynatech One Piece Driveshaft
Comp NSR stage 2 (127200) cams with Livernois limiters
McLeod RST twin disk clutch
GT500 dual fuel pumps
39# injectors
C&L racer intake
Nitrous Outlet Custom Direct port Wet Kit 200 Shot
2x10 pound nitrous tanks
NX Maximize 4 progressive controler
NX SAFE Stand Alone fuel system
Taylor Trunk mount battey relocate kit
Taylor battery Disconnect Switch
Autolite HT0 spark plugs
JPC dyno tune
MSD Window switch 3200 - 6400 rpm
2 NOS Bottle heaters
Cobalt series Nitrous cabin gauge
Cobalt oil pressure gauge (mechanical)
Raptor shift light
Innovate series Wideband gauge
Steeda Underdrive Pullies
Steeda Race Delete plates with nitrous taps
Steeda oil seperator
Kooks Long tube headers
Strange 10 way adjustable struts
QA1 double adj rear shocks
Cobra jet springs all around
Kooks Catted X pipe
Bassani Mufflers
Custom Strut tower brace
CHE K member with torque limiters
BMR K Member
BMR A Arms
BMR Rad support
BMR chassis brace
BMR lower control arms
BMR relocation brackets
BMR Driveshaft Safety Loop
BMR Panhard Bar
BMR Panhard support arm
BMR ADJ Upper control arm
BMR Upper mount
BMR Duometer Upper Bushing
FRPP Girdle
Strange 31 spline axles
Strange c-clip eliminators
MGW Short Throw Shifter
M&H Racemaster drag radials (mounted on stock bullitt rims)
07 Shelby Rims 18x9.5 Nitto NT05R Rubber (street)
Weld RT rims 17x6 (front) and 15x10.5 (rear) with full slick (strip)
Rear sway bar relocate kit
GT 500 Brembo brakes
11.7 @ 122 spraying 200 shot.
Gallery
Comments
Damn dude. Slice that antenna down a bit!!!
Sweet ride you got now Ken. Can I say JEALOUS
300rwhp? I will rape you with a stick! My Fauxbra will smash that **** down to the ground
