General Information
Year
1997
Make
Ford
Model
Mustang GT
Color
White
Packages
Option 248A
1997 Ford Mustang GT (White)
Modifications
Drivetrain
Kenne Bell Supercharger, MPH Kenne Bell Cams, Fox Lake Ported Trick Flow Heads, Ford Racing Iron Block, ARP Head Studs, Canton Road Race Oil Pan, Billet Oil Pump Gears, Thump RRR Tensioner, Comp Cams Adjustable Cam Gears, ARH 1-3/4" x 3" Long Tube Headers, Ford Truck Water Pump, Fore Fuel Rails, Kellogg Crankshaft, JLT next gen Cobra High boost intake, Fluidyne Radiator, 80lb Fuel Injectors, Innovators West 15% OD Damper, Napa Battery, Eagle H Beam Rods, 180* Thermostat, SCT BA 2600, L19 Rod Bolts, JE Custom Pistons 9.2:1, Cometic Head Gaskets, ARP Main Studs, AFCO GT500 Dual Pass Heat Exchanger With Fans.
Interior
Alpine Deck, JL 900/5 Amp, infinity Kappa Speakers, JL 12" W3.
Exterior
Cervinis Cobra R Hood, Cobra Headlights, 03 Cobra Antenna, Weld RTS Wheels.
Audio
Liberty Gears built TKO 500, Moser 31 Spline axles, Eaton Diff, 3.73 Gears.
Suspension
Team Z Relocated Rear Upper Control Arms, Team Z Lower Control Arms, AFCO Double Adjustable Eliminator Coil over Shocks, AFCO 90/10 Coil over struts, 225# front spring, Team Z stock location Rear Drag Spring, Maximum Motorsport caster camber plates.
Wheel and Tire
Weld RTS 15x10, Mickey Thompson 235/60, Weld RTS 15x6
