General Information
Year
1993
Make
ford
Model
mustang
EVERY THING THAT IS DONE TO MY CAR
ELDELBROCK ALUMINUM HEADS
ALUMINUM RADIATOR
ALUMINUM DRIVE SHAFT
CENTER FORCE DUAL FRICTION CLUTCH
STRANGE 31 SPLINE AXLES
EATON 355 GEAR AND POSI UNIT
SUMMIT UPPER AND LOWER CONTROL ARMS
ELDELBROCK HIGH RPM INTAKE MANIFOLDS
BLOCK BORED 30 OVER SO MOTOR IS A 306 INSTEAD OF 302
BBK 70MM THROTTLE BODY
BBK FENDER WELL COLD AIR INTAKE
BBK UNDER DRIVE PULLEY SYSTEM
MSD INGNITION SYSTEM
E303 camshaft
TRI-AX SHORT THROUGH SHIFTER
BBK LONG TUBE HEADER
BBK CATLESS H PIPE
FLOWMASTER ORIGINAL 40'S
EXHAUST CUT OUTS
BE COOL ELECTRIC FAN
355 GEAR IN REAR END
5'' INCH COWL HOOD
5'' MONSTER TACH W/ EXTERNAL SHIFT LIGHT
3 GAUGES DOWN APILLAR, VOLTS, WATER TEMP, OIL PRESSURE
ALUMINUM RADIATOR
E303 camshaft
BBK CATLESS H PIPE
EXHAUST CUT OUTS
5'' INCH COWL HOOD
