Showcase cover image for 95opal's 1995 ford mustang gt vert
General Information
Year
1995
Make
ford
Model
mustang gt vert
1 of 95 opal frost verts with black trim.
ENGINE:
Afr165s heads w/ PS3 spring upgrade
FTI custom cam
Vinton valve seals
Comp cams 1.6 rockers
Holley systemax2 intake
3/8" intake spacer
TFS intake elbow
70mm FRPP tb
95mm P-mas MAF
30#FRPP injectors
BBRC billet aluminum fuel rails
Braided fuel line
Aeromotive A1000 platinum regulator
10.5 Livewire plug wires
Livewire Billet wire seperators
4" polished CAI
K&N filter
Billet Idler and power steering pulleys
Billet smog pump eliminator pulley
Billet Pi-thon hose locks
Custom billet coil cover
A/C delete
Fluidyne aluminum radiator
UPR polished radiator cover
Stewart stage 1 water pump
AFM polished valve covers
150 amp polished ALT
ASP billet under drive pulleys
Pioneer SFI balancer
Energy suspension motor mounts
Mac chrome radiator hose kit
Mac headers
Mac off-road H
Bassani catback
MSD 6al and coil
Walbro 255lph pump
Morosso overflow tank
Zitronics wideband
SCT 4 bank chip
Zex 125 wet shot
MSD window switch
Zex dual purge kit
DRIVETRAIN:
FRPP 4.10s
Pro 5.0 shifter
Super King cobra clutch
FRPP billet steel flywheel
FRPP aluminum drive shaft
T/A Performance girdle
SUSPENSION AND BRAKES:
Steeda aluminum lower control arms
FRPP upper control arms
Eibach Pro kit
Tokico shocks and struts
Steed bumpsteer kit
Steeda STB
Steeda end links
Steeda front and rear sways
MM subs
MM aluminum rack bushings
MM steering shaft
MM caster camber plates
Comp engineering adj. pinion snubber
Cobra brakes frnt and rear
Drilled and slotted rotors
stainless lines
EXTERIOR AND INTERIOR
Saleen s281 bodykit
Saleen heat extractor hood
Saleen s281 wing
Saleen speedster cover
Saleen lightbar
Saleen 18" replica wheels
Saleen windscreen
BFG KDW2 rubber
Rear seat delete
Bullitt pedals
Bullitt shifter bezel
03 cobra shift nob
Corbeau GTS2 seats
Auotometer ultralite triple A pillar guages(water.oil,volts)
Autometer ultralite nitrous pressure guage
Autometer AF guage
White face gauges
Custom instrument cluster bezels
Custom billet sill plates
Gallery
Comments
looking good bro
MM's Coffee Addict
Don't mind if I say that list of modifications is quite remarkable. And it shows in the quality and outright stunning showmanship in every aspect of that car's detail. Absolutely gorgeous. And one of the cleanest 5-liters I've laid eyes on.
