General Information
Year
1997
Make
Saleen
Model
S281
Mods:
Rear End: moser 31 spline axles, FRPP 31 spline trac-lock, 3.55:1 Gears, TA Performance girdle and stud kit. Royal Purple fluid.
Brakes: Cobra front brake upgrade, Hawk pads, Powerslot slotted rotors all the way around.
Suspension: UPR Tubular K member, UPR tubular A arms, Coil over front suspension, Bilstein HD shocks and struts, Saleen Racecraft lowereing springs, FRPP caster/camber plates, Energy suspension Polyurethane control arm bushings and rack bushings, Steeda X2 ball joints, Steeda bump steer kit, Maximum Motorsports XL seriers full length sub frame connectors, Maximum Motorsports lower control arms, UMI performance adjustable uppers, Maximum Motorsports Swarr bar, Steeda HD rear Sway bar, Saleen racecraft front sway bar, Energy Suspension Front sway bar end links and bushings, Maximum Motorsports steering shaft.
Drive line: FRPP aluminum driveshaft, Centerforce dual friction clutch, Steeda heavy duty clutch cable, Steeda double hook quadrant, Steeda firewall adjuster, Red Line synthetic fluid in Transmission.
Motor: Block bored .020+, Mahle 10cc dish forged pistons and forged H beam rods, Stock crank balanced with rotating assembly, FRPP oil pump, Ford Motorsport SVO cylinder heads Ported Polished with a 5 angle valve job, Modular Powerhouse stage II custom grind blower cams, Ford Motorsports SVO intake manifold, BBK twin 62mm Throttle body, FRPP 90mm MAF, JLT cold air intake, Dyno tune.
Fuel: TRE 255lb/hr fuel pump, FRPP 24lb injectors, Proffesional Products aftermarket fuel rails with steel Braided lines.
Exhaust: Mac long tube headers with matching Off Road H pipe, Borla catback , Saleen tips and MIL eliminators.
Interior: Saleen white face cluster guage, LED light swap for blue guages, Blue backlight glow shift boost guage, Blue backlight glow shift wide band with data logging, Saleen Logo door carpet, UPR Billet hvac knobs, headlight knob and defroster button. UPR Billet door handles, 03 Cobra console swap with billet Saleen logo cup bezel, Billet shifter bezel, Brushed finish skull shift knob, Blue backlight shift pattern coin holder delete, Saleen S281 floor mats, Running pony on steering wheel and "Mustang" on passenger side airbag painted metallic silver
Exterior: New Kaenen rear spoiler, Saleen heat extractor hood, Antenna delete, 20% tint on all windows, new metallic silver saleen graphics and windshield banner. Chrome Saleen speedline 18" wheels with Dunlop ssg sport run flat tires.
