Showcase cover image for aluv4speed's 1996 Ford Mustang GT - Built
General Information
Year
1996
Make
Ford
Model
Mustang GT - Built
Fully built suspension, sub frams, & spearco harness weld in bar.
2001 PI DSS Race block with all forged internals
FR500 Wheels Stagered - 315's 555's out back
Cobra big brake kit front and rear
New setup: 628/654 16psi 677/695 18psi ( just swapped in an Eddy manifold, 6061 plenum, 75mm & 4" race intercooler) will re tune in spring. Also going from 3:73 to 3:27.
On3 FF turbo
Turbonetics Benita 78/68 .96ar turbo
E85
80lb injectors, -10feed, -6return
12-1400 Dominator pump
stock heads, stock cam, MHS stage 3 upgraded springs, valve job
tubular K, coil overs, mmr oil pan, mmr windage tray,
Stewart waterpump, 170 reiche stat, underdrive alt and waterpump, ac delete
alum driveshaft and flywheel, spec stage 3+ clutch
Previous:
2.2 Kenne Bell intercooled blowzilla 15.63 psi
2.75 upper carbinite coated & 6.5 lower
76mm idler & 90 mm idler upgrade
NGK R - 3446 ( heat range 7 ) gapped .028
489\487 Stock Heads and Cam
Gallery
Comments
There are no comments to display.
