General Information
Year
2004
Make
Ford
Model
Mustang GT
Color
Competition Orange
Packages
Non ABS car
History
Chased 11's all motor for years. Eventually I started pulling timing and playing with fuel on an old Modular Depot tune. Finally cracked 11's NA 2V on 11/2/14 Running [email protected]
Currently doing a turbo build with a 2V based setup.
Down to finishing wiring. Changing over to manual brakes/steering. Getting 10point roll cage installed. Then off for tuning and back to track to do what I do best. Give no mercy to the car and launching at 6800rpm.
2004 Ford Mustang GT (Competition Orange)
Modifications
Drivetrain
Complete redo of engine compartment. Had major rust issue in frame rails at strut towers. Ended up rebuilding that area and making new front aprons. Hid all wiring. Modified radiator core and moved stock radiator 2" forward. Increasing room to keep fan away from turbo.
Audio
Teksid block,Kellog crank, Manley H beam rods w/ARP2000 bolts, custom cams, worked over 2V heads. Tremec 3650 trans upgraded to 26 spline input shaft, billet aluminum 1-2 and 3-4 shift forks, adapter plate to use Quicktime SFI steel bell housing.
