Showcase cover image for AzSonicSnake's 2003 Ford SVT Cobra
General Information
Year
2003
Make
Ford
Model
SVT Cobra
Mods:
Engine:
-Steigemeier stage 4 ported and polished supercharger
-Kenne bell Boost a pump
-Siemen deka 60lb injectors
-SCT 2600 maf
-Reichard Racing blower spacer
-Metco 2lb lower pulley
-Billetflow 2.76 upper pulley
-SCT chip
-Custom tuned by Devin @ Performance
Solutions (515rwhp, 522rwtq)
-JLT Hi-Boost Intake
-Bassani ss x pipe with high flow cats
-SLP Loudmouth 1 exhaust
-Fluidyne radiator
-Fluidyne heat exchanger
-LFP ice box
-Moroso Radiator Expansion Tank
-Accufab throttle body and plenum
-Optima red top battery
-Billetflow 3 piece pulley kit
Suspension and Tires & Wheels:
-Performance Solution Racing Lightweight K-member
-Maximum Motorsports Caster/Camber Plates
-MMR Coilovers
-Upr Extreme upper control arms
-HPM megabite Jr lower control arms
-Maximum Motorsports full length sub frame connectors
-Lakewood 90/10 front struts
-Tokico Illumina Adjustable rear shocks
-Welded upper and lower battle boxes
-10th Anniversary Red Calipers Front and rear
-Powerslot Front and Rear Rotors
-Weld prostar drag wheels for the track
-Nitto 555r in a 335/35/18 for the street, and M/T ET Drags with tubes and bead locks for the track
(26-10-15)
-Ride rite rear launch air bag
-SLP Line Lock
-Energy Suspension Poly Motor Mounts
-BBS RK Plasma Wheels. 18x8 in the front with a 18x10 in the rear
Transmission and Rear End:
-Spec stage 3+ clutch
-Fidanza flywheel
-26 spline trans input shaft
-LDC clutch freeplay conversion
-Cobra bob stang shifter gasket
-Pro 5.0 shifter
-live axle conversion
-Mosier 31 spline axles
-Eaton True Trac diff
-3.90 gears
-TA Performance diff cover
-drive shaft loop
Interior and Apperance:
-LDC underhood Light
-Tinted Clear corner headlights
-Tinted rear taillights
-Mcullough 5k HID's
-Raptor shift light
-SOS guage pod
-Autometer pro comp boost guage
-Autometer pro comp coolant temp guage
-Custom "SVT" Door Panel inserts
-Mac Chrome Radiator Support Cover
-Skeletor Pony Grill Emblem
Gallery
Comments
He's a chump and his car is slow..oh wait, isn't this Freefallin's profile?! Haha, I can't wait to see it in person Tony! Nie job, sir.
Sloth for President
your car gives me a reason to live
