General Information
Year
2004
Make
Mustang
Model
GT
Stock block, ARP main & head studs, cobra crank, Manly H beam rods with ARP2000 bolts, Wiseco pistons, SHM billet oil pump gears, Meziere electric water pump, stock heads and cams(for now hehe), Reichard intake, Accufab 75mm throttle body, twin ford GT pumps, 60lbs inj, Kooks long tubes, off road x-pipe, flowmaster 40's, Procharger P1SC, 8rib, Procharger 3core intercooler, T56 viper spec, Centerforce DFX, 31spline trak-lok 3.73, cobra brakes w/ drilled & slotted rotors, Tokico adjustable struts, QA1 adjustable shocks, Steeda adjustable control arms, Steeda rear lower control arms, Steeda welded & bolted SFC, mm caster camber plates, upr k-member, eIbich springs, 275's up front, 315's in back
