General Information
Year
2001
Make
Ford
Model
Mustang GT
01 GT 5-speed Black/Charcoal
new build in progress, updated 7/17/10
BUILT, NOT BOUGHT. having a fast car built by someone else is like bragging about how cute your kid is after you let another man knock up your wife. all work is done by these two hands. 3 years ago i didn't even know where the spark plugs on this car were, huge thanks goes to ModdedMustangs for helping me build a monster.
to be installed: Trick flow 44cc heads, turbo cams, big turbo, t-56 or TKO600, McLeod twin disk, alum driveshaft, 31 spline rear, RR or edelbrock intake, etc. the next time the car hits the road it will have 700+ rwhp. Project should be done by spring 2011
she'll look like a "13 second car." goal is 10's in street trim. hoping for 140mph in race trim, with a manual.
already done:
MMR 900 Shortblock (Manley forged H beam Rods, Manley Forged pistons, 03-04 cobra crank, 04 cobra block)
MMR High volume oil pump
Billet Cam Spacers
ARP Headstuds
MMR/Felpro head gaskets
Aluminum Flywheel
Procharger three core intercooler
HPX Slot MAF with custom tig welded intake tube
60lb injectors
04 Cobra tank
Twin GT pumps, PPRV delete
-8AN Fuel line
Fore Fuel rails
Modified FPDM
KB 40 amp BAP
MSD Coils
NGK TR6 Plugs
X-CalIII
PLX DM-100 Wideband
Flowmaster Cat-back
steeda firewall clutch adjuster
steeda tri-ax
MM K Member
MM Tubular A-arms
MM CC Plates
MM Coilovers
Bilstein struts
MM Bumpsteer
MM tie rod ends
MM full length powder coated sub frame connectors
MM HD lower control arms
MM HD Torque arm
MM Panhard Bar
Cobra Brakes
18x9 Chrome DD Bullitts
04 Cobra trunklid
263/35/18 Nitto NT555
6000K HID's
Chin Spoiler
Grill Delete
Tint
last dyno: 529/484
already done:
Billet Cam Spacers
ARP Headstuds
Aluminum Flywheel
60lb injectors
04 Cobra tank
-8AN Fuel line
Fore Fuel rails
Modified FPDM
KB 40 amp BAP
MSD Coils
NGK TR6 Plugs
X-CalIII
PLX DM-100 Wideband
Flowmaster Cat-back
steeda tri-ax
MM K Member
MM Tubular A-arms
MM CC Plates
MM Coilovers
Bilstein struts
MM Bumpsteer
MM tie rod ends
MM HD Torque arm
MM Panhard Bar
Cobra Brakes
04 Cobra trunklid
6000K HID's
Chin Spoiler
Grill Delete
Tint
last dyno: 529/484
