Showcase cover image for Blown331's 1993 Ford Mustang
General Information
Year
1993
Make
Ford
Model
Mustang
Here is a list of what I remember is done to my ride. I may come back and add stuff from time to time as I remember.
MOTOR/FUEL/IGNITION/TRANNY-
Built 331ci stroker
Vortech V2 S-Trim pushing 11 lbs boost
All Probe forged internals with forged Probe Crank
AFR 185cc heads
ARP Head studs/Bolts
MLS Head Gaskets-hate cometics
TrickFlow Street/Strip Intake
UPS Cold Air intake pipe
Big Mouth Air Filter
*Did replace the MAF with a 70mm but cant remember the type I bought*
70mm throttle body
JBA Ceramic Coated Shorty Headers
JEGS off road h-pipe
50 series Flowmasters/Flowmaster axel back--Yes I run full exhaust
MSD 6AL
Vortech Boost/Ignition Controller
42# Ford Motorsport injectors
In tank 255 lph pump-External T-Rex Vortech Booster
New Bell Housing for the Tremec Transmission
Tremec TKO600 Tranny
McCleod Stage 3 Clutch
New and upgraded Cross Member
Tremec Short throw with Tremec shifter knob
Ford Motorsport Aluminum Radiator
New balancer but that's a given since I am S/C
7 Quart oil pan
SUSPENSION/REAR END, etc-This area needs to be changed. My dad originally set the car up for more of a road racing set up. When he passed I took the car and have been chaning things up since then.
Eibach 1 1/4" Lowering Springs
Hotchkis Pillow Tops in the front
Koni adjustables in the rear
I know it has upgraded sway bars but I am not sure what
Strange 31 Spline Axels with 3" Bolt Studs
Cobra Carrier with Kevlar Clutches
Ford Motorsport 3.73 Gears
Ford Racing Aluminum Driveshaft
Subframe Connectors-Weld In
Deleted Quad shocks to fit my Mickeys
All tuning was done by Protech Perfomance in Lubbock, Tx. All was done with Sniper tuning software but the car has yet to go on the dyno for the final numbers. I run a 3-way flip chip. 92 Octane tune, 50/50 mix with 92/112 octane, and a 112 octane only tune. I run Mickey Thompson E/T Streets-27x10.50.
Gallery
Comments
There are no comments to display.
