General Information
Year
2003
Make
Ford
Model
Mustang GT
Vortech V1 S trim
3.12 Pulley
107.0" 5061070 Dayco belt
Procharger 3 core intercooler
Cxracing 3" piping welded
HPX slot style maf
Votech Mini Race bypass recirculated
KMS Powerpipe
AEM Dryflow 4x9.25 filter
ARH Longtubes
ARH Catted x
JBA Catback
Accufab Plenum
Accufab 70mm T/B
39lb. Injectors
SVT Focus Pump
KB 40amp BAP
Moser 31 spline axles
FRPP T lock
FRPP 4.10
FRPP Girdle
FRPP UCA
MM LCA
MM Frame Connectors
MM C/C Plates
Steeda Sport Springs
Moog Tie Rod Ends
Steeda Ball Joints
MGW Shifter
SLP Linelock
Raptor Shift Light
Brakemotive drilled/slotted rotors
Mach 1 Chin Spoler
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled (3.6, 9psi): 356/371, 3,575lbs, [email protected] 1.86 60'
Intercooled (3.33, 9psi): 361/370, [email protected] 1.67 60'
Intercooled (3.12, 12psi): 403/394, [email protected] 1.78 60'.
411/402 on a different dyno.
Work done by Hans at Deans Performance.
Tuned by Tim Barth at Modular Powerhouse.
3.12 Pulley
HPX slot style maf
KMS Powerpipe
ARH Longtubes
ARH Catted x
JBA Catback
Accufab Plenum
Accufab 70mm T/B
39lb. Injectors
SVT Focus Pump
KB 40amp BAP
FRPP T lock
FRPP 4.10
FRPP Girdle
FRPP UCA
MM LCA
MM Frame Connectors
MM C/C Plates
Moog Tie Rod Ends
Steeda Ball Joints
MGW Shifter
SLP Linelock
Raptor Shift Light
Mach 1 Chin Spoler
