General Information
Year
2001
Make
ford
Model
dhg bullitt
2001 DHG Bullitt, 5.3 big bore stroker, forged bottom end, 11.3:1 compression, tfs 38cc heads, mhs stage 4 n/a tfs cams, mmr billit cam spacers, cloyes adjustable cam gears, jlt bullitt cai, kooks long tube headers, bassani exhaust, mezier electric water pump, t-56, 26 spline input, dynotech aluminum drive shaft, MCleod flywheel, MCleod rst twin disc clutch, frpp 31 spline cobra diff, moser 31 spline axle's frpp 4:10 gears, frpp high flow oil pump, ford gt fuel pump, 42 lb injectors, qa1 single rear shock, tokicko illumina front struts, mm caster camber plates, steeda full lenght sub frame connectors, steeda upper and lower rear control arms, fluidyne radiator, steeda tri ax shifter, and still waiting for a tune
