General Information
Year
2000
Make
Mustang
Model
GT
Performance:
Vortech V1 SI trim
3.33 pulley
CX Racing IC
Greddy RS blow off valve
39lb cobra injectors
SVT Focus fuel pump
40 amp KB Boost a pump
Autolite 103 spark plugs
Trick flow plenum
70mm Roush throttle body
Bassani O/R X-pipe
Borla Stinger catback
3.73 gears
Bored .30 over (so I was told)
Transmission:
Stock T-45
Pro 5.0 shifter
Ram HDX clutch
Steeda double hook quadrant
Firewall adjuster
Steeda adjustable clutch cable
Suspension:
Upper and lower control arms (not sure of the brand)
Aluminum driveshaft
H&R super sport springs
Subframe connectors
KYB adjustable struts
KYB adjustable shocks
Caster camber plates
Engine strut brace
Tires:
275/40/17 BFG G-Force drag radials (track)
245/40/18 Bridgestone Potenza RE760
295/35/18 Bridgestone Potenza RE760 (DD)
Vortech V1 SI trim
3.33 pulley
CX Racing IC
SVT Focus fuel pump
Trick flow plenum
Bassani O/R X-pipe
3.73 gears
Transmission:
Stock T-45
Pro 5.0 shifter
Ram HDX clutch
Firewall adjuster
Suspension:
Aluminum driveshaft
Subframe connectors
Engine strut brace
Tires:
