General Information
Name
Scarlett
Year
2006
Make
Ford
Model
Mustang GT
Color
Red with black stripes
Packages
Deluxe
I bought this red beauty on 26th October 2013 completely bone stock in Deluxe trim, with a plastic-rimmed steering wheel and 4-gauge instrument cluster. Since I'm incurably infected with mod fever, it wasn't going stay that way for long as I gradually added some choice upgrades!
Performance
JLT series 3 CAI & SCT X3 tuner
DIY ported stock throttle body (used)
DIY charge motion delete plates (used)
Steeda underdrive pulleys
JBA replica shorty headers
Ford Performance X-pipe with Pypes high flow cats (used)
Brenspeed 91 octane custom tune, 6500rpm rev limiter
Driver & Passenger side eBay air/oil separators
Stock 1/4 mile performance: 13.61 @ 103.58 (3660lb race weight)
Current 1/4 mile performance: 12.59 @ 109.06 (3635lb race weight)
Stock dyno numbers: 271rwhp @ 5800rpm, 289rwtq @ 4300rpm
Current dyno numbers: 321rwhp @ 6100rpm, 333rwtq @ 4400rpm
Drivetrain HP/TQ loss is 11% at maximum HP & 10% at maximum TQ, making the outputs 360hp & 370lbft at the crankshaft.
Brakes
Powerslot cryotreated front rotors
Hawk Performance ceramic front brake pads
Performance
Brakes
Modifications
Drivetrain
McLeod RXT twin disc clutch assembly
McLeod billet steel flywheel
McLeod braided SS clutch hydraulic line
Barton short throw shifter
DSS 3.5" aluminum driveshaft
Interior
6-gauge instrument cluster (used)
Info/Setup/Reset switch assembly
Leather steering wheel (used)
SilverHorse Racing trunk release switch
Exterior
2010 Mustang GT engine heat shield
DIY engine undertray extensions
Redline Tuning hood struts
CPC radiator extension covers (used)
BBK intake manifold plenum cover
VMS Racing chrome strut tower caps & nuts
DIY 8" shorty antenna
Lighting
CDC sequential taillight kit
Exhaust
Pypes high-flow cats (used)
GT/CS axle-back mufflers
Suspension
BMR rear lower control arms & relocation brackets
Prothane rear sway bar & end link bushings
Energy Suspension rear track bar bushings
Prothane rear differential carrier bushing
Energy Suspension front control arm bushings
Energy Suspension front sway bar bushings
Ford Performance strut mounts
Wheel and Tire
Chromed 18" Bullitt wheels
255/45R18 tires
255/45R18 tires
