General Information
Year
2001
Make
Ford
Model
Mustang GT Convertible
Drivetrain
Engine
-Teksid aluminum block 0.030” over (3.582” bore)
-Kellogg crank (3.750” stroke)
-Manley H-beam rods
-Diamond pistons 23cc dish w/ valve relief (9.4:1 CR)
-Total seal moly rings
-Clevite H-series bearings
-ARP 2000 rod bolts
-ARP 8740 main studs
-Canton 20-939P windage tray
-Canton Road Racing Oil Pan – 15-784
-Melling 10227 billet geared high volume oil pump
-15/16” 4V pick-up tube
-Trick Flow track heat twisted wedge heads 44cc
-ARP 8740 head studs
-Fel-Pro permatorque head gaskets
-TFS spec MHS stage 2 blower cams (225/232 @ 0.050; 0.550/0.540 lift; 114 LSA; 110 ICL)
-Stock PI intake with aluminum crossover
-Steeda intake spacer
-P&P plenum
-PP 75mm TB
-JBA shorty headers with Stage 8 locking header bolts
-BBK off-road x-pipe
-Flowmaster original 40 series catback w/ 4” tips
-Meziere EWP
-3 bolt tensioner
Transmission
-4R70W
-Dirty Dog 3200 stall single disk lockup converter (conservative stall for autox)
-8 bolt SFI approved flexplate
-Transgo HD Shift Kit
-FRPP aluminum driveshaft
Rear end
-Stock
Power Adder
-P1SC; 3.7” pulley
-3 core intercooler
Fuel System
-SVT focus pump
-42lb/hr injectors
-KB 40amp BAP
-Stock lines/tank/rails
Suspension
Front
-MM K-member w/ 2 point brace
-MM standard offset LCA’s w/ urethane bushings mounted in the lower location
-Stock spindles
-Bilstein HD struts
-MM CO kit with 275lb/12” springs
-MM CC plates
-MM solid adjustable steering rack bushings
-Federal Mogul inner tie rods
-MM bolt through style adjustable bumpsteer kit
-Stock GT swaybar
-MM steering shaft
-Cobra Brakes with Hawk HPS pads
-Stoptech braided lines
Alignment
Caster: 6.5*
Camber: -1.0*
Toe: 0.25* in
-MM FLSFC’s
Rear
-MM XD adjustable LCA’s
-Stock UCA’s
-Bilstein HD shocks
-Eibach Pro-kit springs
-MM PHB
-Stock sway bar
-Stock brakes with Hawk HPS pads
-Braided lines
Misc.
-Twillfast RPC black convertible top
-CDC light bar
-Optima red top
-center dash gauge mount
-PLX wideband
-Autometer boost gauge
-Chin spoiler
-Smoked front headlights with clear corners
-Euro style clear lens foglights
Comments
There are no comments to display.
