General Information
Year
1992
Make
Mustang
Model
LX 5.0
Engine:
Trick Flow track heat intake
Trick Flow track max roller cam
Trick flow twisted wedge 61cc heads
Crane 1.6 energizer rollers
76mm C&L MAF
C&L TrueFlow elbow
75mm Accufab TB
K&N box filter
BBK AFPR
24lb injectors
Holley 255lph
BBK 1 3/4" longtubes
BBK o/r x-pipe
American thunder exhaust
Drivetrain:
FRPP aluminum driveshaft
FRPP 3.73 gears
pro 5.0 shifter
summit driveshaft safety loop
Suspension:
Tokico Dspec struts
Tokico Dspec shocks
MM caster/camber plates
Ford HD rear upper control arms
MM Lower control arms
MM sull flength subframe connectors
Comments
There are no comments to display.
