Showcase cover image for DJ Wolfe's 2008 Ford Mustang
General Information
Year
2008
Make
Ford
Model
Mustang
SUSPENSION:
STEEDA- Strut Tower Brace, Sub-Frame Connectors, Ball Joints, Bumpsteer Kit
EIBACH- Sport Lowering Springs and Sway Bar Kit
CHE-Driveshaft Safety Loop, Lower Control Arms and Relocation Brackets, Adjustable Upper control Arm and Mount, Adjustable Panhard Bar and Brace.
MAXIMUM MOTORSPORTSs-Caster/Camber Plates
TOKIKO-D-spec Adjustible Shocks and Struts
DRIVETRAIN:
FRPP- Limited Slip with 4.10 gears
HURST- Short Throw Shifter
Ram- Powergrip HD Performance Clutch
ENGINE:
STEEDA- Under Drive Pulley, CMCV Plates, Yellow Valve Covers
PROTHANE- Motor Mounts
K&N- Oil Filter
Comp Cams-XFI Stage 2
Stage 2 Ported Heads with a 5 axis Valve Job
MMR- Forged 302 ci stroker rotating assembly
ARP- Hardware all around
9:1 compression 377 rwhp
INDUCTION:
AIR-AID- Cold Air Intake and Throttle Body Spacer
EXHAUST:
BORLA- Stingers 4"
KOOKS- Long tube Headers with Catted X pipe
PYPES- Hangers
ELECTRONICS:
SCT-X3 91-OCT Race Tune Murrillo Motorsports
PIONEER- AVIC-D3 in-dash GPS
SILVERSTAR- Bright White Bulbs
Passport 9500i (plugged behind dash)
BRAKES:
BAER - 6 Piston Arizona Copper Front Calipers, 2 Piece 14" Drilled and Slotted Rotors, Carbon Ceramic Pads
BODY:
CCW- 505A F: 285/19/30 R:305/19/30 BridgestoneRE050A (Locking Nuts)
ROUSH- Louvers
CDC- High Flow Grill
3M-29% Tint All the way around
STACK RACING-Short 8'' Antenna and Hood prop kit
SHELBY- GT 500 Duck-tail, "Powered by FORD" "5.0", and "Stroker" Badges
SCOTT DRAKE- Rear Deck Lid Panel
Silver Horse Racing - Lower grill insert
G2- Black Caliper Paint
FORD- Cali Special Front and Rear Bumpers
Lower Grill Insert
Corbeau - CR1 Racing Seats
Completely Gutted Interior...
Gallery
Comments
Photos Coming in a Month or so when the engine work is done...
