Showcase cover image for e3sean's 1988 ford mustang lx
General Information
Year
1988
Make
ford
Model
mustang lx
ENGINE: (363)
DART IRON EAGLE 8.2 BLOCK 4.125 BORE
DIAMOND 4.125 DOME PISTINS
SCAT 5.4 H BEAM RODS
SCAT FORGED 3.4 CRANK
MACHINE WORK DONE BY STANDARD MACHINE IN GLENDALE AZ
DOUBLE ROLLER ADJUSTABLE TIMING CHAIN
SCHNYDER RACING CUSTOM CAM 807/765 LIFT
HUGE CUSTOM MOROSO OIL PAN
HEADS:
1ST GEN TRICKFLOW T/W HEADS
2.08 INTAKE 1.6 EXHAUST VALVES
PORTING DONE BY STANDARD MACHINE IN GLENDALE AZ
FLOW 338 INT 286 EXH
JESEL SHAFT MOUNT ROCKERS
MANLY NEXTEK SPRINGS 700# OPEN
TITANIUM RETAINERS
CUSTOM PUSHRODS
AIR/FUEL:
PROSYSTEMS 1000 CARBORATOR
EDELBROCK SUPER VICTOR MANAFOLD
HOLLEY FUEL PRESSURE REGULATOR
BG400 FUEL PUMP
AEROMOTIVE 100 MICRON FUEL FILTER
5 GALLON FUEL CELL
-10 FEED -8 RETURN LINES
ALL BLACK NYLON EARLS LINES AND FITTINGS
TORCO 114 OCTANE
EXHAUST:
KOOKS 1 3/4 5 PEICE(per side) HEADERS 3.5" COLLECTOR
PYPES 3.5" DIY X PYPE
3.5" DYNAMAX BULLET MUFFELERS
3.5" FLOWMASTER TURNDOWNS
SUSPENSION:
WOLFE RACECRAFT 12 PT CHROMOLY CAGE
THROUGH FLOOR SUBFRAME CONNECTORS
UPR K MEMBER KIT
UPR A ARMS
UPR ANTI ROLL BAR
TEAM Z LOWER CONTROL ARMS
GRANATELLI DOUBLE ADJUSTABLE UPPER CONTROL ARMS
UPR SPHEREICAL SOLID UPPER BUSHINGS
DRIVETRAIN:
WELDED AXEL TUBES
MOSER 31 SPLINE AXELS
MOSER C CLIP ELIMINATORS
MOSER FULL SPOOL
4.56 GEARS
ATI 28oz fLEXPLATE
JW ULTRA BELLHOUSING
5500 HUGHS 8" CONVERTER
CUSTOM A TO Z PERFORMANCE C4
TRANS BRAKE
ALUMINUM DRIVESHAFT
DRIVESHAFT SAFTY LOOP
ELECTRONICS:
MSD DIGITAL 6 IGNITION BOX
MSD HVC COIL
TAYLOR HAYWIRE WIRES
MSD DUEL PICKUP DISTRUBITOR
FAST CRANK TRIGGER
INNOVATE DUEL LM2 WIDEBAND/DATALOGGER
AUTOMETER ELECTRONIC OIL PRESSURE/FUEL/WATER TEMP GAUGES
OTHERS:
BOGART RACING WHEELS
M/T 28 10.5 DRAG TIRES
CERVINIS 2.5" FIBERGLASS COWL HOOD
CUSTOM GAUGE CLUSTER
CHECKER SPECIAL RACING SEATS
ELECTRIC WATER PUMP
ELECTRIC FANS/CUSTOM ALUMINUM SHROUD
3 CORE RADIATOR
BE COOL OVERFLOW
Gallery
Comments
There are no comments to display.
