General Information
Year
2000
Make
Ford
Model
Mustang GT
Electric Green 2000 Mustang GT, 4.6L motor, T-45 5-speed transmission
Best time: 13.03 @ 111.48 on all-season street tires
................12.73 @ 111.36 on drag radials
Engine horsepower: Approximately 450 hp at the crank (383/.85
.....SAE 383 rwhp @ 5870 rpms/370 rwtq @ 4930 rpms
.....Same pull: STD 396 rwhp/ 370 rwtq.
.....Previous Dyno's: SAE 370/377 and Mustang Dyno 385/370
Horsepower mods:
.....Procharger P1-SC, 3.7" pulley, 8.9 lbs boost, 3-core intercooler
.....FRPP 42 lb injectors, 255 lph SVT Focus fuel pump
.....DiabloSport MAFia, SCT 4 Chip w/custom tune
.....BBK 75 mm TB/High Flow Elbow
.....Meziere Electric Water Pump
.....BBK LT Headers with Catted X-pipe
.....Magnaflow Cat-back
Drivetrain mods:
.....Hurst Billet/Plus Shifter
.....Stage 2 King Cobra Clutch
.....FRPP 3.73 Gears
.....Explorer 31 Spline Differential
.....Strange 31 Spline Axles
.....Axle Tubes Welded
Suspension/Handling mods:
.....FRPP Cobra 13" Front Brakes, GT 10.5” rear brakes
.....Slotted/Drilled Rotors, Hawk HPS pads
.....Strut Tower Brace
.....UPR 4-bolt Caster/Camber plates
.....Edelbrock Sub-Frame Connectors
.....Torque Boxes Welded
.....MM FRPP Upper Control Arms
.....UPR ProSeries Adjustable LCA
.....Koni STR.T struts & shocks
Interior mods:
.....White Reverse Lighting Gages
.....Autometer Phantom II Boost and Fuel Pressure Gages
.....Autometer Pro-Pod Instrument Cluster Bezel
Exterior mods:
.....Cervini 95 Cobra R hood
.....Mach 1 Grill Delete
.....Mach 1 Front Wing
.....Rear wing set back 2”
Tires and Wheels:
.....SVE 10th Anniversary Anthracite Wheels
..........four 17x9 and two 17x10.5
Winter: four 275/40 BF Goodrich G-force Comp-2 A/S tires
Summer Rear: two 315/35 Nitto 555R
Comments
There are no comments to display.
