Showcase cover image for Fox-back's 1990 FORD MUSTANG LX
General Information
Year
1990
Make
FORD
Model
MUSTANG LX
302 BLOCK BORED 0.30 OVER (306)
351 D00E HEADS
FORD RACING RODS AND PISTONS
ALL NEW:
TITANIUM VALVES
VALVE SPRINGS
GUIDES
ROCKER STUDS
HARLAND SHARP ROCKERS
FORD RACING F303 CAM
UNDERDRIVE PULLEYS
PROFESSIONAL PRODUCTS UPPER AND LOWER INTAKE MANIFOLD
1 INCH TRICKFLOW SPACER
70MM THROTTLE BODY
BBK 90MM MASS AIR AND COLD AIR INTAKE
PROFESSIONAL PRODUCTS FUEL RAILS
FUEL PRESSURE REGULATOR
30LB INJECTORS
BILLETT SMOG ELIMINATOR
HIGH FLOW FUEL PUMP
MSD PRO BILLETT DISTRIBUTOR
MSD WIRES AND COIL
GRIFFIN FOUR CORE ALUMINUM RADIATOR
MAC EQUAL LENGTH HEADERS
MAC OFFROAD H-PIPE
FLOWMASTER 2 CHAMBER MUFFLERS
RICHMOND 5SPEED TRANSMISSION
ZOOM STAGE III CLUTCH
BBK SHORT THROW SHIFTER
31 SPLINE AXLES
AUBURN REAR DIFFERENTIAL
4:10 GEAR
FULL SUB-FRAME CONNECTORS
MILES ON MOTOR 6K
DYNO 302 HP 376 LBS
1/4 MILE ???
Comments
There are no comments to display.
