General Information
Year
1985
Make
Ford
Model
Mustang SVO
78000 original miles
Turbonetics t3/t4 57mm turbo
46 lb Ford injectors
8UA ecu swap
Big VAM
Tokico Illumina 5 way adjustable shocks and struts
All the bushings front and rear have been changed over to eighther alluminum or delrin
Megabite Jr. lower control arms andf stock upper control arms
Heavy duty Global west swaybar
Global west caster camber plates
Wilwood brake on rear 4 piston calipers with 12.125 rotors
Stainless braided brake lines
2005 GT 17 inch wheels
3" down pipe and 3" all the way out the back
NPR front mount intercooler
Walbro 255 lph fuel pump
Billet adjustable fuel pressure regulator
Ford motorsport plug wires
Turbo XS RFL blow off valve
Steeda tri-ax shifter w/ Hurst arm (short or long which ever you prefer)
UPR clutch quadrant
(2) 2 5/8 Autometer Ultralight Boost and Fuel pressure
8UA ecu swap
Big VAM
UPR clutch quadrant
