Showcase cover image for Froush's 2002 Ford Mustang
General Information
Year
2002
Make
Ford
Model
Mustang
2002 Ford Mustang "v6"
Exterior:
Roush Stage 3 Body Kit
Custom Ducktail Spoiler
Vfn Cajun pro hood
01+ Gt scoops
Custom Emblems
Painted mirrors
Skeleton mustang emblem
Custom paint job
15x10/17x4 Centerline Quilifiers with mt et streets with Champion Beadlocks
Short Antenna
20% tint
Smoked Headlights
Sequential Taillights
Engine/Drivetrain:
V6 swapped to Teksid 302 stroker 9.2:1 comp ratio
Teksid Block
Kellog forged crank
Rpm stoker H beam rods
Manley 23cc pistons
Foxlake Stage 2 Heads with oversized valves and comp beehive springs
MPH Kb custom cams
Arp headstuds
Kenne Bell 2.2
Ported intake
Custom inlet
Billetflow hub and pulley
Coolant mod
Zex nitrous kit
Solid motor mounts
8 rib upgrade
18% innovators west overdrive damper
Mezierre electric water pump
sct ba2600
egr delete
Trunk mounted Dirty Dick 5 gallon ic tank
Frozenboost heat exchanger
JLT RAI
SCT xcal3 tuner
Burnt Bronze carbon fiber valve covers
SVE Radiator
Mac LTs
VRS o/r x pipe
SLP lm2s dumped
Trans:
4r70 built by Lidio at Alternative Auto
4200 Precision Industries multidisc converter
Lentech MVB with TB
Hurst Pistol Grip Quarter Stick Shifter
Hayden 679 Cooler
LFP Deep Trans Pan
PA Flexplate
FRPP aluminum Driveshaft
Rear:
FRPP 3.55 gears
33 spline moser axles with c clip eliminators
Moser Spool
Mac differential cover
Fuel:
Dual divisionx stryker 340s
Upgraded 8an line
Upgraded wiring
dual fpdms
60lb siemens deka injectors
PPRV delete
Suspension:
UPR tubular k-member
UPR a arms
UPR 14" 175# coilovers
Lakewood 90/10 struts
Mac cc plates
Maximum Motorsports flsfc's
UPR Pro series double adjustable uca's/lca's
UPR Pro series spherical bushings
Wild rides torque box reinforcements
Strange 10-way adjustable shocks
Lakewood driveshaft safety Loop
Eibach rear drag springs
Drag bag
Donathen tubular front bumper
Brakes:
Brakemotive drilled and slotted rotors
Hawk hps pads
SLP linelock
Interior:
Kirkey seats with covers
Custom "FROUSH" gauge cluster with LED's (looks bright blue)
Aeromotive interceptor gauge with air/fuel wideband
Roush led boost gauge
Prosport Fuel/Oil Pressure and Trans Temp gauges
Custom Vent pods
Raptor Shift Light
Competition Engineering 8 point roll cage
Simpson 5 point camlock harnesses
Grant steering wheel
Rear seat delete
a/c delete
Comments
There are no comments to display.
