General Information
Year
2007
Make
Ford
Model
Mustang GT
2.6L Kenne Bell intercooled on 10 lbs. of boost, tuned by Jim at Turbo Connection in Edwardsville, IL
Stang-Hi Performance oil catch can
Brisk Silver Racing spark plugs
UPR off-road X-pipe
Stillen ground wire kit
Spec 2+ Clutch
Spec Steel flywheel
FRPP Stainless Steel braided clutch line
Steeda Tri-Ax shifter
Dynotech 1-piece aluminum driveshaft
BMR driveshaft loop
BMR K-member and A-arm brace
Steeda Tubular radiator support
CHE upper & lower control arms
Steeda LCA relocation brackets
Motive Gear 4.10 ring & pinion
Moser 31 spline axle shafts
Detroit Truetrac differential
Stoptech steel braided brake lines
Hawk HPS brake pads
Powerslot rotors
SLP line lock
Meziere Electric water pump
Thumperrr Racing serpentine belt tensioner
PA Performance 200A alternator & wire kit
Autometer Cobalt Fuel Pressure and Boost gauges
AEM wideband gauge
M&H Racemaster 325/45-17 Drag Radials
California Special front bumper and side scoops
Cervinis Ram-air hood
CDC sequential tail lights
Shorty Antenna (For aerodynamics, yo!)
"RICE COOKER" 3rd brake light (5 h.p.)
"Trunk Monkey" button (3 h.p.)
"JUSTAGT" Custom plates (12 h.p.)
UPR off-road X-pipe
Spec 2+ Clutch
Spec Steel flywheel
BMR driveshaft loop
Hawk HPS brake pads
Powerslot rotors
SLP line lock
AEM wideband gauge
