General Information
Year
2004
Make
Mustang
Model
GT
Procharger P1SC-2, 3.70 pulley, 3 row intercooler, #42 injectors, Trick Flow upper plenum, Mac 70 mm T/B, Lightening MAF, NGK TR6 Plugs, Diablo 2 stage chip, Focus fuel pump, 417 HP-Flywheel, 378 HP-Rear wheels, BBK Valve Covers, Canton coolant & power steering resevoirs, O/R X-pipe, Cobra front & rear brakes with slotted & cross drilled rotors, steel braided brake lines, Eibach sportline springs, Eibach sway bars, KYBs, MM Bump steer kit, MM Caster/Camber Plates, Urethane motor & trans mounts, subframe connectors, Elk Strut tower brace, Roush diff girdle, MM firewall clutch adjuster, 18" Konig wheels, Simco indigo instrument cluster & center dash pod, MGW shifter, 03/04 Cobra front bumper facia, VIS Carbon Fiber 2000 Cobra R hood.
