General Information
Year
2000
Make
Mustang
Model
GT
::Interior::
B&M Short Shifter
Ford GT Floor Mats
::Exterior::
Front Chin Spoiler
Smoked Headlights
Smoked Taillights
Pypes Exhaust Badge
Front Grille Delete kit
::Engine::
PP 70mm Throttle Body
Accufab Plenum
Steeda CAI w/ Heat Shield
Diablo Tuned
MAC LT Headers
Lethal Performance Cated Xpipe
Pypes Exhaust
::Trans::
3.73 gears
Ford Heavy Duty Clutch
::Tires::
Nitto Drag Radials on Stock Rims
Coming Soon!!!
::Suspension::
GR40 Super Street Starter System
Heavy Duty TorqueArm (Solid Axle Applications)
Panhard Bar (Solid Axle Applications)
Lower Subframe Connectors
Anodized Aluminum Front and Rear Coil-Over Kit 700# F 250# R
Koni Single Adjustable Street Shocks and Struts
Griggs Racing MCA 4000 N with Urethane Bushings
Urethane Front Control Arm Bushings
Delrin Rear Lower Control Arm Bushings (IRS Only)
Urethane IRS Cradle to Body Mount Bushing (Includes 14mm bolts and nuts)
Urethane IRS Differential Front and Rear Mount Bushing Kits
GR40 Billet Aluminum Bumpsteer Kit
Billet Aluminum GR40 Camber Plates
::Rear End::
31 Spline Moser Axles
31 Spline Eaton Diff
Aluminum Drive Shaft FRPP
Gear box bearing kit
::Engine:
working to 700rwhp)
MMR 900 short block
PP Heads
Boost Cams
Vortech s/c with intercooler
Lighting
Hyper Amber OEM fog lights
HID 5k kit
Exterior
VIS CF Cowl 3" hood and CF Trunk Lid
Stubby Antenna
Wheels
GT4 Hyper coated Rims front and rear 18x9F 18x10.5R
Nitto NT05 Tires
Paint Job after all finished
Depending on the cost of the whole project....May turn in and get a 03/04 cobra and or GT500
B&M Short Shifter
Ford GT Floor Mats
::Exterior::
Front Chin Spoiler
Smoked Headlights
Smoked Taillights
Pypes Exhaust Badge
::Engine::
Accufab Plenum
Diablo Tuned
MAC LT Headers
Pypes Exhaust
::Trans::
3.73 gears
::Tires::
Coming Soon!!!
::Suspension::
::Rear End::
::Engine:
MMR 900 short block
PP Heads
Boost Cams
Lighting
HID 5k kit
Exterior
Stubby Antenna
Wheels
Nitto NT05 Tires
