Showcase cover image for Hedobob's 95 GT Coupe
General Information
Year
95
Make
GT
Model
Coupe
BBK shorty headers, Magna Flow Stainess X pipe with convertors and a Magna Flow cat back stainless mufflers tail pipes, underdrive pulleys, performance chip, 3:73 Richmond Gears, shift kit, B&M shifter, cold air kit. drilled and slotted rotors ceramic pads 4 wheel disc, Aluminum ford racing driveshaft, Eibach Pro lowering kit including springs and sway bars, pionion snubber replaced with one in kit, aftermarket upper and lower control arms Energy suspension bushings and spring insulators, synthetic grease in all fittings and Monroe Sensa Trac struts and shocks, Enforcer reprogrammed AODE transmission with shift kit and 2600 stall rated for 500 HP/500 lbs torque
Gallery
Comments
There are no comments to display.
