Showcase cover image for Jetflo's 2001 Ford Mustang
General Information
Year
2001
Make
Ford
Model
Mustang
Base model 5spd manual purchased from an enterprise used lot in 2007
Ported stock upper intake
3.5" ID K&N clamp on hidden inside stock air box
Half shafted and ported stock throttle body
SCT Advantage III tuning software, LiveWire 9600 and AEM wideband
Steeda sub frame connectors
MM caster camber plates
KYB GR2s
stock springs
Steeda upper and lower control arms
Steeda urethane steering rack bushings
Prothane front sway bar bushings
3.73:1 gears
TLok limited slip
double hardened axles
trued axle housing
Steeda Tri Ax shifter w/ "billard ball" knob
Ford Racing Aluminum Driveshaft
Enkei RFP1 17" forged wheels
Bridgestone Potenza RE760 SPORT 245/45 17" tires
JBA shorty headers
Stock cats
Pypes V6 X pipe
Magnaflow catback 2.5" mandrel bent dual exhaust
Braille battery
Mini torque starter
spare tire delete
Gallery
Comments
There are no comments to display.
