General Information
Year
2000
Make
FORD
Model
MUSTANG GT
Vortech V1 T-trim Supercharger
Vortech 8 rib pulley set up
MMR MOD 900 forged short block
Patriot stage 2 ported stock heads
Houston Perf. s292 blower cams
TFS Intake oval upper
Accufab single blade oval TB 1694 CFM
Innovators West 18% over drive Crank Pulley
Meziere elec. water pump
AFM Power pipe
K&N air filter
NGK BR7-EF
SCT Xcal 2 by Dave Guy @ SGS
60lb Siemens/Deka Fuel injectors
Kenne Bell 40 amp Boost A Pump
10G Fuel pump wire upgrade
03 Cobra fuel Hat
03 Cobra tank
Dual Lincoln Aviator fuel pumps 271lph
Zone 5 stage 1 FPDM
180* Thermostat
Driverside head cooling mod.
DIY Ebay intercooler set up 31x12x4
XTD stage 3, 6 puck clutch
Ford 3.73 Gears
31 spine Ford Explorer Diff. with extra clutches
USA Alloy 31 spine axles
SLP line lock
MAC headers
3 in. custom x pipe
3 in. Dynomax bullets dumped at axle
Glow Shift Boost Gauge
Pro. Sport Fuel pressure gauge
Jegs Racing Seat
RCI 5 point seat belt driverside
SCT 2400 MAF Diablo
MAFia MAF extender
EGR delete Summit
1 QT Vented Oil Catch Can
MMR HO oil pump w/Cyro gears
GoodRidge Braided front break lines
Patriot titanium retainers
Patriot stainless steel valves
Patriot bronze valve guides
Viton Valve seals
CHE upper/lower rear control arms
UPR tubular k-member/ A-rms Summit
UPR coilovers n 4bolt cast/camber plates
Custom full lenght subframe connectors
Laurel Mt. Solid engine mounts
KYB Shocks oe replacements
Black Cobra r DD wheels
17x10.5 Sumitomo 315/35/17 rear
17x9" Sumitomo 255/45/17 front
Custom 8 point roll cage w/swing out door bars
Welded torque boxes
Welded axle tubes
Laural Mt. Poly Carrier Bushings
03 Cobra Brakes
Brembo cross/sloted rotors
AFM Power pipe
K&N air filter
NGK BR7-EF
03 Cobra fuel Hat
03 Cobra tank
Zone 5 stage 1 FPDM
180* Thermostat
Ford 3.73 Gears
SLP line lock
MAC headers
3 in. custom x pipe
Jegs Racing Seat
SCT 2400 MAF Diablo
MAFia MAF extender
EGR delete Summit
Viton Valve seals
Welded torque boxes
Welded axle tubes
03 Cobra Brakes
