General Information
Year
2001
Make
Ford
Model
Mustang GT
Stock Block stroked to 5.0L.
Eagle crank and connectings rods.
Diamond pistons with 9.6:1 compression.
Patriot stage 2 heads.
Comp270 Cams.
BBK cold air intake and shorty headers.
Pypes o/r x pipe w/ magnaflow cat backs.
Accufab 70 mm throttle body and plenum.
Steeda timing adjuster, underdrive pullies, and tri-ax shifter.
Sct livewire tuner.
Spec billet flywheel and clutch.
3.73 gears.
Made 324.2 rwhp and 350.2 torque on a conservative tune.
(Tuner says that his dyno reads 10 percent shy of the real number)
Comp270 Cams.
Sct livewire tuner.
3.73 gears.
